MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
8.0 Question for Dar or Pe
Old 08-28-2008 | 09:51 PM
Default 8.0 Question for Dar or Pe
Hello Gentlemen
I recently broke-in & installed a New MVVS 8.0 engine on a 3D plane.
The problem I have is the carb barrel starts to stick after the 2nd flight.
I then take the barrel out & remove a small burr from housing & 360 grit emery paper the barrel & reassemble & it is fine for 2 more flights before sticking again.
Rather than do the same procedure again I decided to ask the experts as the old style carbs never gave me an ounce of trouble.
Suggestions please??
Thanks, Mike
Old 08-29-2008 | 05:32 PM
Default RE: 8.0 Question for Dar or Pe
The barrel groove top probably is sharp, and runs against the guide slot bolt. this causes a slight burr to form. If you chamfer the top of the cut groove, there will be no burr to interfere with barrel movement/rotation.
OTOH, It may be just plain debris or a binding idle needle inside the spray bar, so check/clean/alighn very well.
Old 08-29-2008 | 06:16 PM
Pe,
Thanks for the fast response.
I needed your input before i did just that.
Thanks, Mike
