MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
mvvs 26 soft mount?
Old 02-09-2010 | 12:04 PM
sandseeker's Avatar
Default mvvs 26 soft mount?
Can the mvvs 26 be soft mounted (dubro/hyde) or should it be hard mounted?
chris<br type="_moz" />
Old 02-09-2010 | 04:19 PM
Default RE: mvvs 26 soft mount?
MVVS has their own soft mount system.
Starting with the radial back mount, you can fit their iso mounts as used in the 3361 backplate systems.
The engine is held quite firm, yet allows sufficient vibration damping to be classified as an excellent soft mount.
Old 02-10-2010 | 08:05 AM
sandseeker's Avatar
thanks Pe, I have the soft mounts for my mvvs 45cc....these the ones? Do you have a picture or diagram of the set up?
chris
Old 02-10-2010 | 09:32 AM
http://mvvs.nl/MVVS/rearmountmanual45-58.doc
