cg & h&l settings for rudder-aile.-elev.
I HAVE A NITRO YAK 3D 50 56" VERSION 2 AND THE MANUAL DOES NOT HAVE SETTINGS FOR AIR.-ELEV.-RUDDER.
aLSO DOES NOT GIVE CG. .Where can I get this information.
Bob
Bob
As far as C.G. you are always safe starting out at about 25% wing chord length from the LE at the fuse.
As far as throws, that's up to you. Check out the throws for other similiarly sized planes.
I never bother with this though, I max out my throws for high rates, but with median mechanical advantage (or better!), and then set my low rates to about 50-60% of this.
Expo 30 low, 50% high.
