wing set for edge 540t 50
RE: wing set for edge 540t 50
PM John about this here.
Note however that you are better off either fixing your existing wings or just buying a new plane.
Most ARF manufacturers charge quite a bit for the wings, so consider that a wing replacement for most ARF's is about the same as the cost of replacing this plane.
How bad is the damage you sustained?
Let's see half the cost of a new plane for a set of wings, versus a whole new plane and parts?
Hmmm tough call.
I'll fix the wings or order a new one.
Hmmm tough call.
