OS 160 Shortening stock muffler
My Feedback: (16)
I have a H9 Cap 1/4 scale and is trying to install the stock muffler. I would not fit until i removed the center extension portion of the muffler. I was wondering what this would do to the engine? I was told that this will shorten the life of the engine. Will i gain or loose power by doing so? Any info would be appreciated.
thanks
Smokey
thanks
Smokey
IL
Smokey,
Your poor 160 will soon be "smokey" if you run it without the extension in the muffler. That large expansion chamber is necessary for proper operation of the engine and, in particular, your engine will overheat very rapidly running in that configuration.
My Feedback: (16)
poor 160
The way the bottom of the firewall is set up does not allow me to install the extension portion of the muffler. I originally had a slimline pitts muffler but this was too loud for my flying field. I was using an APC 18x8 prop with 10% cool power fuel. Can you recommend another pitts style muffler? How about putting a Jtech snuffler at the end of my stock shortened muffler? Can doing so increase my muffler volume area? I'm just looking for ideas to keep the engine running good and quiet.
Smokey
Smokey
OH
Smokey, check this one out, this is what I use, and its not that loud. Daz..
http://www2.towerhobbies.com/cgi-bin...1&I=LXUL60&P=7
IL
I've never tried that smokey, so i really have no idea; however, that smaller can is going to make an aweful lot of back pressure, far more than the engine is designed for, and i really don't think its going to work.
You might contact slimline, jtec, or similar to ask about a "quiet muffler" for your engine that will fit.
My Feedback: (16)
prop
I shortened the muffler and it fits nicely in the cowl. My question now is what prop to use to try to slow the engine down in hopes to keep it cool. Apc brand would be preffered.
Smokey
Smokey
