Glow plug reaches ??
Hi,
I have two OS engines, a .28F heli and a .32F heli. I'm unsure of the reach that is required for these engines. My needle settings are constantly changing and they are both hard to start on the first flight of the day. I purchased both these engines used and I just want to make sure they both get what they require. I put a long plug in the .28 and it seems to hold the tune a lot longer. The one I took out of the engine seems to be between the short and the long! Could you please elimate this variable for me. I have seen to date 3 different reaches of plugs. How many different reaches are available?
Thanks a lot
Steve
Thanks a lot
Steve
IL
Steve,
I believe there are currently two but there have been numerous in the past and we're talking about a very old engine here. I would go with a long, idle bar plug. I think you'll find that will make a big difference in that old engine's performance. It also may simply be worn out.
Those old engines which we know we have parts for are listed in the parts listings at:
http://www.osengines.com/parts/discontinued.html
http://www.supertigre.com/parts/index.html
If your engine is not listed here, we have little or no information available to assist you.
These gentlemen rebuild old motors and stock large quantities of older engine parts. Either of them may be able to assist you:
1) Preferred means of contact: PetesRC @ aol.com.
Pete's Hobbies
1814 Nelson SE
Grand Rapids MI 49507
Fax- 616-245-3106
Phone calls will be greeted with an answering machine. Please leave Name, Ph No. and, preferably, what you are looking for:
PH 616-243-9149
(Please note that there may be as much as a one week delay in response time due to extensive travel to shows, swap meets, and FLYING TIME! Lucky them! :-)
2) Model Airplane Engines- Antique to current, to use, to get out of production parts off of, or general purpose. 1200 Engines on My list - Buy- sell-Trade! send 33 cent stamp to get list or write to:
Contact: Bob Boumstein/ HWC PO Box 94 Boystown NE. 68010
E-mail : [email protected]
Fax 24hours : 402-334-4173
Phone: WEEKENDS ONLY 402-334-8688 (messages returned on Sunday only!) No
calls before 9AM CSTor after 9PM CST
3) Gene Steinkamp
8773 Russet Drive
Cincinnati, OH 45239
4) PISTON RINGS ONLY:
For discontinued piston rings, try contacting Frank Bowman. He manufactures repro and current piston rings for our modeling needs. He can make standard and Dykes type rings. If he doesn't have the ring you need in stock, you send the piston and cylinder and he will make it then. prices are $7.50 up to $9.50. His work is of the finest quality.
Frank can be reached at [email protected] or 1-505-327-0696 ( 6pm to 9pm mst. weekdays) and the following address:
Frank Bowman
1211 N. Allen
Farmington, NM. 87401
5) Alternatively, you might try placing an ad on one of the internet lists such as rec.models.rc.***, www.rcuniverse.com and some of the many other r/c related sites to attempt to purchase the item which interests you.
6) You might try swap meets, club sales, estate sales that list hobby equipment, etc.
Sincerely,
Mrs. AnnMarie Cross
Senior Manager, Proprietary Services and Support
Great Planes Model Distributors
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
Pete's Hobbies
1814 Nelson SE
Fax- 616-245-3106
PH 616-243-9149
3) Gene Steinkamp
8773 Russet Drive
Frank Bowman
1211 N. Allen
Sincerely,
Mrs. AnnMarie Cross
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
