os 70 surpass throttle postition Q...
VA
Hi,
I have a OS 70 Surpass I and am mounting it on a Somethin Extra ARF. With the supplied mounts and the down pointing throttle arm, I can't possibly run a throttle cable to the throttle arm. How can i move the throttle arm to a "up" position so I can have the cable run over the mount. If this doesn't make sense, please let me know.
Best,
Harold
Best,
Harold
Throttle Arm
Not sure if this is what you mean but all that holds the throttle arm on to the barrel is a set screw. Just loosen it and you can rotate the throttle arm to any location you wish.
Hope that helps,
Rod
Hope that helps,
Rod
