95 rv piston removel
![](/forum/images/badges/premium_vendor.png)
To disassemble the O.S. FS-95V engine, you remove the cylinder head, slide the cylinder liner straight up out of the case, and then pop the connecting rod off of the crankshaft. You may have to pry the rod off the crank, so use a carriage bolt and slide the head under the rod and rock the bolt to lever off the rod.
