O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 160 FX
Old 09-01-2004 | 02:18 AM
tIANci's Avatar
Default OS 160 FX
I just purchased an OS 160FX for my World Model Extra (80") and would like to query on a few things:
i. running in ... what would be the best method for an engine this size; and
ii. would it be advisable to install an oscilating (non-powered) Perry pump, I was informed I need to tap a pressure nipple from the back plane.
Thanks!!!
Old 09-01-2004 | 03:24 AM
My Feedback: (67)
Default RE: OS 160 FX
I you are planing on useing the Perry Oscilating Pump, there is no need to drill and tap the back plat. I have a Perry Oscilating pump on my OS 91FX and it runs great. Just follow the instructions on installation and the Pump will work out great.
NEDYOB
Old 09-01-2004 | 11:11 AM
Bax
Breakin should be performed per the instructions.
You don't need a pump unless the fuel tank is going to be far away from the engine. Muffler pressure is usually enough, unless your muffler doesn't provide enough pressure. Many after-market mufflers do not provide enough pressure, and you may have to restrict the exhaust outlet on those mufflers to generate good pressure to the tank.
Oversize fuel tubing and a clunk with a larger I.D. will not hurt fuel draw. Large engines draw a lot of fuel, and fuel-line drag can become a factor.
Old 09-01-2004 | 07:50 PM
tIANci's Avatar
Thank you ...
