O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 46 FX carb problem/question,,,
Old 08-28-2005 | 05:16 PM
Default OS 46 FX carb problem/question,,,
so we have a problem with the low-end needle changing/turning in flight on my son's OS 46 FX plane carb, after every flight I have to reset the low-end needle,,, so what's the best fix ??
is there an O-ring on the low-end needle ??, I looked at a carb rebuild kit and I only saw an O-ring for the high-end needle,,,
this motor only has about 12 gallons on it...
thank's !!
Jim
Old 08-29-2005 | 09:47 AM
Bax
Default RE: OS 46 FX carb problem/question,,,
The idle needle has an o-ring to keep it from moving. If it's old or damaged, it could allow the idle needle to slip. The part is:
Here are the stock numbers and list prices of the parts you asked about:
OSMG7392 22781800 O-RING SMALL #2K/#2SB $2.29
These parts can be ordered through any hobby retailer who sells O.S. Max engines and accessories.
Old 08-30-2005 | 01:14 AM
OK, thank's Bax !!
Jim
