O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
.61 FSR
Old 11-20-2005 | 07:57 PM
jlkonn's Avatar
Default .61 FSR
If I needed a complete set of allen head bolts for the head, rear cover, etc. of a .61 FSR what would I order?
Thanks!
JLK
Old 11-21-2005 | 11:23 AM
Bax
Default RE: .61 FSR
Verly likely the bolt set for the .61 SF would work.
Old 11-25-2005 | 08:43 PM
Default RE: .61 FSR
Bill, can I return just the crank case and have you guys change out the bearings for me. It is the same OS 61 FSR Special Edition. I need it to fly as the NIB Special Edition I just bought will forever remain dry,
John
Old 12-04-2005 | 12:31 AM
Default RE: .61 FSR
What is the difference between a 61 FSR and a 61 FSR Special Edition besides the gold head and the inscription on the mounthing lug? Anything?
Old 12-05-2005 | 11:21 AM
Bax
Default RE: .61 FSR
The .61 FSR Special Edition was brought out several years after the .61 SFR wento out of production. Other than the gold head and "Special Editch" molding on the case, tere's nothing different about it.
Old 01-18-2006 | 08:08 PM
My Feedback: (36)
Default RE: .61 FSR
Hi Bill,
I just got the 61 FSR gold head special edition NIB. It did not come with the manual. Can I get the manual for it anywhere? what prop, plug, fuel for this engine?
Thanks in advance.
Old 01-19-2006 | 11:17 AM
Bax
Default RE: .61 FSR
Please send us an email to the address below and we'll be glad to send you a manual for the O.S. Max .61 FSR.
Old 01-19-2006 | 08:11 PM
My Feedback: (36)
Default RE: .61 FSR
Sent email, got the instruction right away. Thanks for quick service.
Old 10-01-2006 | 01:00 AM
Default RE: .61 FSR
I just got a 61 FSR but it did not have a carb. After much questioning I decided to go with the 7D carb. This carb has a huge venturi. My 61FX went bye-bye so this engine is replacing it. Since I put the FSR in my a-plane it went from only coating the horizontal with oil to coating the left bottom right horizontal vertical......should I continue. I Do realize that this is an older engine but holy cow. it seems like more oil is coming out of other places than the muffler. Is it spitting back out the venturi. I have this engine on an ultrastick so it is side mounted.
Thanks!!!!!
Old 10-02-2006 | 11:14 AM
Bax
Default RE: .61 FSR
The #7M carburetor came with the .61 FSR, but is no longer availble. The O.S. Max #7D carb was intended for the .91-1.08 FSR engines. Spitting raw fuel at midrange and low throttle settings would be expected. O.S. no loner makes a carb that fits the .61 FSR.
Old 10-03-2006 | 02:38 AM
Default RE: .61 FSR
I was flying the other day and realized while I was adjusting the carb that the spray I was getting was coming from the front of the engine. I am going to check on replacement bearings.
Old 10-03-2006 | 09:21 AM
Bax
Default RE: .61 FSR
Spray from the front of the engine indicates a worn case-to-crankshaft fit. The front bearing does not make the seal. The seal is made by a close fit between the case and the crank forward of the carburetor. If a lot of raw fuel is spraying out, then you need a new case, crank, or both. Those parts would be problematic to get at this time, because the engine's been out of production for so long.
Old 10-04-2006 | 12:51 AM
Default RE: .61 FSR
Bax,
this doesn't make sense to me because the crank (on the front of the engine) doesn't make contact with the case. The crank goes through the bearing and the bearing contacts the case.
Old 10-04-2006 | 10:17 AM
Bax
Default RE: .61 FSR
The seal at the front end is made by a thin film of oil between a close-fitting crank and case. Front bearings do not seal the front of model engines.
Old 10-08-2006 | 12:41 AM
Default RE: .61 FSR
Understood. Thanks. I took my engine apart and discovered a dished out spot in the front of the crankshaft. I immediately knew what was missing (the WOODRUFF KEY). Could this be part of the reason I am getting so much oil out the front?
