O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
O.S 46LA starting problems
Old 11-27-2005 | 01:37 PM
Default O.S 46LA starting problems
hello,
Have had a 46 LA in my piper cub and it wont start at all, i have double and triple checked all the batteries, fuel, connections everything and have even tried different glow plugs. Im using a high torque starter but the bugger wont start, it is fairly hard to turn over.
Anyone know what i should do?
Old 11-28-2005 | 12:46 PM
Bax
Default RE: O.S 46LA starting problems
If the engine turns over smoothly when you remove the glow plug, except for a slight tightness at Top Dead Center, then the engine should be good. If it's hard to turn over even with the plug removed, you may have a bent connecting rod.
Sometimes, a lean run or dirt can cause problems with the bushing...dirt or overheating can cause a bad fit....the engine will then tno turn easily. A new case, and sometimes a crank may be needed. However, at the costs to replace those items, you may as well purchase a new engine.
Generally, if an engine has good compression, good fuel, and a good glow plug, it will fire. If the carb's clean and the fuel can flow freely, then it should run once it starts.
Your O.S. Max .46 LA shoudl be able to be started with teh high-speed needle opened to about 2-1/2 turns out from closed. The air-bleed screw shold be set so that one-half of the airbleed hole is obstructed by the screw. Lightlly choke the engine and start it at 1/4-1/3 throttle.
If the engine's particulary hard to turn over, then something's broken or bent.
Old 11-28-2005 | 12:53 PM
the engine has never been run before, and i have just cleaned it so i will check the air bleed again.
