O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
70FS Split Cotter Removal
Old 03-29-2003 | 01:45 AM
Default 70FS Split Cotter Removal
Can someone tell me how the split cotter pin is removed from the valve stem? Thanks in advance.
Rick - AE9D
Old 03-31-2003 | 04:10 PM
Bax
Rick,
You have to remove the cylinder head from the engine and set it on a small piece of wooden dowel so that the valves won't move. You then push the outer ring of the valve spring retainer down. We made a tool out of a piece of metal tubing that will press all around the outside of the retainer. A light tap with a small tack hammer will pop the retainer loose from the clips.
Old 04-01-2003 | 03:11 AM
Default Thanks
Thanks for the info Bill. I wasn't sure how the clips were in the retainer. I presumed the retainer needed to be pushed down, but I didn't want to force it too hard. A little coaxing as you suggested and the retainer pushed down, then I was able to replace the valve spring.
Thanks again!
Rick - AE9D
