LOOK WHAT I JUST GOT
MT
For my Birthday WWWWWOOOOOOOOOOHHHHHHHHHHHOOOOOOOOOOO
lots of fun stuff coming up now
Model LaserPoint 24
Controller 16 bit CPU
Control panel
Over-head, 2x8 L C D, 13-button touch thin-film keyboard
Driver
High stepping motor, micro-step driver
Maximum paper feed width
730mm (28.7")
Max cutting width
625mm (24.6")
Max cutting speed
400mm/s
Max cutting thickness
1mm
Pressure 0-400g
Mechanism precision
.1mm
Repeatable precision
<+- 0.1mm
Type of plot pen
All types Diameter 11.4mm plotterpen
Protocol DM-PL HP/GL automatic identification
Interface USB
Power supply
110V/220V AC
Power consumption <100VA
Model LaserPoint 24
Control panel
Driver
730mm (28.7")
Max cutting width
625mm (24.6")
Max cutting speed
400mm/s
1mm
Pressure 0-400g
Mechanism precision
.1mm
<+- 0.1mm
Type of plot pen
Interface USB
Power supply
110V/220V AC
AZ
RE: LOOK WHAT I JUST GOT
ORIGINAL: Ttam Says Blarg
Do you mind if I ask what it does?
ORIGINAL: Beasley1
It cuts out decals or stickers. That what I do for a living.
MT
Yes its a vinyl cutter and ill be using it for paint masks and several other applications
they are $499 direct from www.uscutter.com but they also have them listed on ebay http://stores.ebay.com/USCutter-for-Vinyl-Cutters-etc I got mine for 310.00
How much does on of those cost?
NC
MT
GA
my friend did the graphics business for a while. he has a JSI cutter. he's lettered a few stock cars and such. he charged $1,900 to letter 1 stock car. he also made logo's and stuff for like $40 an hour. he gave it up though because his parents hassled him about it and he got tired of it all and he gave everything to them lol
we are also friends with some 2 other guys who do the graphics stuff and they both have $20,000 printer/cutters.
I would have been impressed if you got a CAD-CAM 3-axis CNC machine. That way you could have custom designed your wown RC parts and fabricate them from scratch using alum billets.
PA
ORIGINAL: SAVAGEJIM
NC
ORIGINAL: SAVAGEJIM
MT
ORIGINAL: Beasley1
Why? Do you have one? Not every one is made of $$$. You know how much a cnc machine cost?
ORIGINAL: SAVAGEJIM
ORIGINAL: madmax22
I thought it was a CNC machine then i saw US cutter on it... hmm... a CNC machinge would be a VERY nice gift!!!
ORIGINAL: SAVAGEJIM
ORIGINAL: Beasley1
ORIGINAL: SAVAGEJIM
ON, CANADA
I think my company spent somewhere around $3 million for two very large 3 axis CNC machines. Expensive, but they can fit our products' hulls which are 11'x13'x24' steel. If you want something hobby sized you can make your own CNC router for $500 and use free software. It wont cut metal but plastics are ok. If you want a hobby size CNC mill capable of cutting metal you should be looking at converting manual mills which on the cheap is $600 for the mill, $300 for electronics, however much you want to spend on tooling (Id say minimum of $300), and an old computer. AutoCAD is only good for 2.5d. For 3d you really want something like Inventor, Solid works, Catia, Solidedge, etc. You use a program between the model file and the CNC to specify tool paths, feed rates, etc. I don't think you can draw a box in AutoCAD (or any program), hit send, and watch the CNC whittle away. CAD and CAM are two separate things.
