Go karts/dune buggies
Anyone have any? Anyone use a street bike engine (600cc - 13000cc) to powers their kart or dune buggy?
I found a 99 ZX6 engine and go kart frame fairly cheap I'm looking at getting. [>:]
Please post pictures of your karts or buggies.
RE: Go karts/dune buggies
ORIGINAL: sheograth
There's mine, haven't driven it this year though
Moderator
Yeah it's a modified LS1, does around 600HP. I haven't dyno'd it since I bought it but the previous owner and builder had paperwork that stated that - and I can believe it after driving it a few times. It's rather overpowered for it's weight.
ORIGINAL: sheograth
AZ
my go-kart, its only got a 250cc in it, but when it is gone, we're going to get a rhino engine and put in it. right now it sucks in sand, only moves about 5 mph in the sand because of no traction
ORIGINAL: Stampede Killer
ON, CANADA
[link=http://london.kijiji.ca/c-cars-vehicles-ATVs-snowmobiles-dune-buggy-with-600-cc-ninja-engine-500-OBO-W0QQAdIdZ118899295]This[/link] has been tempting me since lunch.
This is mine and my dads. Has a 245hp honda 3.0 v6 with a biult 6 rib bus trans.18inches of travel in the front and 20out back with king dual rate coilovers.
AZ
ORIGINAL: JB COMP
I'm hoping to find something like what you have to drop a street bike engine in. Drop the tire pressure down when you drive in the sand and try not to cut the wheel alot.
yeah but then when you hit the rocky stuff you risk damaging rims, we live by a riverbed and drive down into it and then get to the desert terrain. this doesn't fit in the bed of a truck, you have to get an extra wide trailer
ORIGINAL: JB COMP
AZ
ORIGINAL: JB COMP
You could get an air pump and a 12v battery to carry with you so you drop them down when you need it, and pump them back up. Also just dropping the tires from 18-15 PSI down to 11-9 PSI should help out a lot.
ORIGINAL: JB COMP
lol their actually at 25psi, because thats what the side of the tire says. their 25 inch tall tires, taller then stock rhino tires
ORIGINAL: JB COMP
ORIGINAL: JB COMP
25" tires are a good size, I'm hoping to run 25' tires on mine (when ever I get one)
AZ
ORIGINAL: JB COMP
Wow never would thought they where run at 25psi. I'm used to dirt bike tires being 8-15psi and also airing down truck tires to 20-15psi.
ORIGINAL: JB COMP
ORIGINAL: JB COMP
ORIGINAL: DarkFire989
So Cal. That thing is dirty! Is that thing handbuilt or bought?
FL
Sheesh all the pictures make my go karts look pathetic!!!
I don't have a picture of this one
http://www.youtube.com/watch?v=0C5M_8WsCh4 (smaller but 10X more fun)
The other
http://www.youtube.com/watch?v=K_bbvsmahR0
I've also got a minibike
http://www.youtube.com/watch?v=j_kYW0rrx4Y
The other
ORIGINAL: 500 lb. koolaid man
The other
The other
What size tires are on both of those karts?
NC
yall are running some serious psi in those tires! both of my 4 wheelers run at NO MORE than 8 psi. most of the time I run them around 3psi on the 4x4 and about 6psi on the sport quad.
ORIGINAL: fatphatboy88
[X(] How to the tires stay on the rims? Are you sure your gauge is reading right? On the bikes (mainly 450's) tires set at 10psi or less have a big chance of the rim spinning in the tire and cutting the stem off. (unless you run 2 rim locks)
ON, CANADA
ORIGINAL: JB COMP
ORIGINAL: hands without shadows
ATV tires have a massive bead and no inner tubes. I've run rear wheels down to 3 psi on my quad with no beadlocks and no slipping and its a 450.
ORIGINAL: JB COMP
FL
