OMP Edge 54
RE: OMP Edge 54
Just about everyone including me now are putting the throttle servo in the fuselage behind the engine. Use a mini servo like a Hitec 81 or similar, cut the hole in the left side behind the engine opening and then drill a 3/8" hole through the front and into the center of the wing between the two R1 ribs (just like the tail servos). Obviously this is easier if done before the building but can be done afterwards as well.
