OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
Kat 46 - 4/40 hardware?
Old 10-26-2006 | 11:27 PM
Bass1's Avatar
Default Kat 46 - 4/40 hardware?
Hi, i just set up my kat 46 with 4/40 pushrods and 4/40 clevisis etc. I did a nice job but now that I really look at the hardware I think I may have gone into "overkill mode"! What do you think, should I step down to 2/56 rods and clevises? The supplied rods seem a little on the thin side to what I am used to using. Thanks again
Old 10-26-2006 | 11:31 PM
My Feedback: (33)
Default RE: Kat 46 - 4/40 hardware?
If weight is not a problem, leave it alone. If weight is a problem, go back to the 256 and use the metal clevis. Happy flying!
Old 10-27-2006 | 06:49 AM
AFSalmon's Avatar
4-40 is overkill for a 40 size model. But like Teebox says if weight is not a concern leave it alone. Also be careful with metal clevises especially on the thtottle. Metal to metal vibration is very bad and causes RF interference. I don't like to use metal clevises even on the control surfaces unless I have 4-40 locking nuts as well. Ony do that on the bigger planes though.
Old 10-27-2006 | 02:37 PM
Banned
I use 4-40 hardware on all my profiles (40 through 100 size). There's no such thing as "too strong" and the weight penalty is minimal (less than a quarter of a tank of fuel in fact).
It also means that I can carry one set of spares to the field.
I used to run 2-26 hardware until I had a pushrod connector fall in half in my hand on my old Katana P's elevator linkage (after many hours and more than a few "unplanned arrivals"). It seems it had fatigued then cracked and it was only because I *do* preflight my models that I caught it in time. I've never had that experience again since shifting to 4-40.
Old 11-06-2006 | 03:38 PM
AFSalmon's Avatar
4-40 hardware is overkill for 40 size planes. Much easier to work with and plenty adequate for 40 size models. I use quality clevises on the control surface and "Z-bends" on the servo arm. Never fails unless you crash! Stick with the manufacturers recommendations Bass1. Use good 2-56 hardware and you won't have any failures.
