Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Simple Question, please help
Old 12-31-2003 | 12:50 PM
Default Simple Question, please help
This might be a silly question, but it has got me thinking ??
I am starting to gt all my stuff together for my 1st parkflyer ( and trying to do it right )
My 1st plane is the GWS E-Starter, I'll be using a 3cell E-Tec 1200 for power and a CC pixie20p ESC. Here is my question.
It states in the manual to use 7.2 - 8.4 volt battery I am using well over that will the ESC protect the stock motor (EPS-350C) from being damaged due to the higher voltage, and if so how does it do it ??
I read alot, but I need this put in simple terms..I just don't get it !?!
Old 12-31-2003 | 01:51 PM
scott88-RCU's Avatar
Default RE: Simple Question, please help
What ESC are you using?
Old 12-31-2003 | 01:57 PM
Castle Creations Pixie 20p
Old 12-31-2003 | 03:28 PM
No, your ESC won't protect your motor. At 11v, don't expect your motor to last more than 10 flights. I ran a EPS300 at 9.6v, and got an average of 20 flights per motor. That's when I gave in and went brushless.
Old 12-31-2003 | 03:36 PM
Really, Hmmm well that is not good news... so would it be wise to start off with a lower voltage pack, say a 2 cell 7.4 volt Lipoly pack
I am looking at brushless in the future but not on my 1st plane, My thinking was off on the battery packs. good thing I own two 7.4 volt packs to start with.
thanks
Old 12-31-2003 | 07:52 PM
Use the 7.4v packs. S300's aren't real happy at over about 75 watts. Prop it for around 8 amps.
Mike
Old 12-31-2003 | 08:31 PM
I have a S-350, I did some digging and found out it can be done, by changing the prop, according to GWS web site there EPS's can take the higher voltage, so I see what happens for now ..
I keep you posted
HAPPY NEW YEAR !!!
Old 12-31-2003 | 11:27 PM
Cant the prop be changed to handle it? Im running 11.1 lypol's on my SS with a 1049 GWS prop with no probs.
Anyone know a chart showing prop pulls?
Old 01-01-2004 | 12:57 AM
Yep it's the amps that cause the problem. Since amp draw rises with volts, you can see why people have problems going to higher volts.
If you prop for around 5-7 amps, you should get some reasonable life out of the motor.
Jason
Old 01-01-2004 | 05:37 AM
Lock
according to the GWS charts I should be pretty safe you can find them here:
http://www.gws.com.tw/english/produc...owersystem.htm
just select what you have, at what voltage and you'll see the amp draw that best suits..
very good info
