beginner plane
NJ
welll you have a triton charger, do you want to fly with li-pos? either way i think that the slowstick would be a great plane for you, i had one as my first park flyer and second plane. its a great plane and really fun to fly
thanks....
looks like tower has them...now if I get one under the needed things it doesnt mention a rx? which one would I need? I'm assuming a micro one.
http://www2.towerhobbies.com/cgi-bin...&I=LXHCJ2&P=RF
FEATURES: Fuselage: Aluminum channel
Wings: One-piece foam construction
Landing gear: Pre-bent one piece wire with two 76.2mm diameter wheels
and one 25.4mm diameter tail wheel and tail skid wire.
Hardware: All necessary hardware included
Motor and gearbox with preinstalled plastic mount
Can be constructed with a removable tail also as a glider
Warranty: GWS guarantees this kit to be free from defects in both
materials and workmanship at the date of purchase
INCLUDES: Aluminum fuselage channel,EPS-400C motor system.EP-7035 prop
main landing gear,tail skid wire,main wheels(76.2mm),tail wheel
(25.4mm),spinner,glue,rubber bands,all necessary hardware and
photo-illustrated instructions,
REQUIRES: Speed Control: Or auto-cut-off
Battery: 2/3 AA cells 270-400mah or AA cells 600mah 7.2V
Charger: Timed or peak for 2/3 AA cells
Radio: 2-4 Channel
Servos: 2 Naro,Micro,or Mini servos
(1-elevator, 1-rudder)
Misc. Items: Building and field equipment
Required for removable tail units in addition to the above is a
electric drill,hacksaw and 1mm drill bit.
Radio: 2-4 Channel
My Feedback: (22)
FL
well I can tell one to stay the h away from! I am an experienced flyer and know something about rc in spite of the parkzone owners smart ass comments ..I bought an edge 540.with 25 years under my belt i do believe I can handle it .but when it arrived it went to together rtather quickly but didnt work.okay I was the dumb one this time I installed the double aa batteries wrong.that should suggest the tx is cheap.. and I got that reversed and still no results.the tx works and the li po's indicate full charge..I havent flown electric just giant and sport gass but this toy leaves alot to be desired so dont buy it .
