Parkzone North American T-28 Trojan
#326
FL
RE: Parkzone North American T-28 Trojan
hey guys i finally decided to t28 electronics and put my own and maiden today for a little while it was to windy for me so i brought it in. this plane is great i love it
now i want to put a camera under the plane to fly over my property and video tape my land i live on 66 acers no trees so if any of you guys live in the orlando or kissimmee area
you are welcome come over i have 150 feet long & 10 feet wide paved runway that my friends made for me . so does anybody know of a good but not expensive camera
#327
MN
UPDATE:
Brought her out to fly this evening before the sun went down and she flew great with the 3 new efite servos installed. I received 2 new digital servos from parkzone today and after my flight I cam home an plugged them in just to see if it was originally 3 bad servos, but I got the same result as before with glitches and the motor firing up ever few seconds. I called Horizon to let them know, they said that there might be a possibility of the servos and futaba receiver not liking one another. That sounds odd to me. BUT I am happy it works now without problems. Hope this info helps someone else out with a similar problem.
Has any one looked at adding some rocket pods, bombs or missiles to theirs? If so where is a good resource on guides on how to build them to scale or in general?
-Kassun
-Kassun
#328
NC
ORIGINAL: icejay55
http://www.hobby-lobby.com/video-camera.htm
Not a cheap one, but works great.
#329
My Feedback: (123)
MS
Here is a great cheap decent quality picture. Just remove it from the strap (unclip it) and place it on the airplane. It will record over 30 minutes and its CHEAP.
http://www.bestbuy.com/site/olspage....=1153337209556
#330
HI there I just purshaced the trojan and well love it. Question for you guys, I also purchased a master airscrew 9x7 three blade prop and was wonder if someone could tell me which prop adapter I need to mount this. It doesn't fit over the adapter which came with the trojan. If you guys could help me out please. Thanks.
#331
A prop reamer can be used to make the hole the proper size. See your LHS. Or use a drill. If the hole is too big already then you can get adapters that fit in the prop hole. I'd use caution with the three blade prop however. I wanted to buy one too but I was too concerned about damage to the motor or esc. I don't have a meter to check out the draw the three blade prop would be putting on the electronics. I watched a guy helping another modeler at the field a few weeks ago. He had a meter and you would be amazed at the difference a small size change can make in AMP draw. I think the stock ESC is pretty borderline to begin with. Did you get a prop for electrics? If you got one intended for gas motors it's going to be heavy and draw even more amps. Let us know if it works out. I still want to get one, even if it's just for show and I put the stock prop back on for flight.
#333
ORIGINAL: hyperdyne
I put my T-28 on the power meter with stock esc, prop, and 3s 11v lipo pack. System was drawing around 19-20 amps at WOT.
#334
MN
Here are some pics of my t-28, I started to add in some pannel lines for detailing the model. I am using a HB pencil and will use a light grey marker for the final lines.n
-Kassun
-Kassun
#335
TX
hey guys
any of you guys had any luck on repairing a broke wing. broke my super cub wing a little off center
clean break any ideals.
are should i buy a new one
areeves
areeves
#338
Does anyone know what motor shaft fits the included motor? The specs say is a 480, but the shaft looks different than the 480 shafts on e-flite's site. It is an e-flite motor, no?
FL
hey guys thanks again for the info on the camera i got that tony hawk helmet cam it worked pretty good here is a video of it
http://www.youtube.com/user/jalamo523
#340
IceJay,
Cool vid. Can the camera be rotated to show a forward view? I think that would look good with a cowl shot looking through the prop disc. Good thing you fly electric and not nitros. You'd have some very irritated neighbors.
#341
FL
yeah it rotates all the way around i can get front or rear view. oh my my neighbors they all fly they are just afraid to here I'm the only one that will fly in our sub division i normally go to our farm which is about 4 miles away but when i don't feel like driving i just fly here
#344
FL
ORIGINAL: S3etigoHide
Nice vid icejay55! I love the view of all the back yard pools, to bad no girls are in them.
#346
FL
A water baced paint like Krylon Fusion and H2o will work fine. I used fusion on my paint earlier in the thread, here's the links below.
http://www.rcuniverse.com/forum/fb.asp?m=6546441
http://www.rcuniverse.com/forum/fb.asp?m=6565694
#347
Bigtone, I had seen that post but since neither of those two shafts appear to be the right one I was hoping someone here had reached a more definitive answer. I have an e-mail in to Parkzone, hopefully they reply with some good news.
My right aileron servo stripped in flight. I'm sure someone with more experience might have been able to save it. However, with me at the controls, it ended in a ugly way.
FL
I called and the service rep told me I have to buy a new motor. There is no replacement shaft. They also won't tell me who makes the motor for them. They tried to tell me it was an e-flite park 480. Well I have a Brio with a park 480 in it and a mini pulse with a park 450 and it is substantially bigger. Kind of upsets me that the support is so poor for this outrunner motor. The shaft comes out very easily. Guess I will have to remove it, put a micrometer on it, and go to one of the Chinese web pages to find a new shaft. Guees maybe I won't be buying products from them again.!!!
#350
Hi Bigtone,
Did you find out if the problem on your T-28 was the motor or ESC (or both)? Did Horizon cover it under warrenty?
