Slow stick Forum!!
#426
RE: Slow stick Forum!!
I finished the wing as per instructions using the new clear plastic insert for dihedral etc.....but its nowhere near as pronounced as my old SS wing!!!
#427
The older wing (no insert and more dihedral) has been great for flying for over one year with no handling problems.....I'm a little worried about the 'new' one.......I'll send pics of all 3 wings together for comparison purposes. Strange!!!!
#429
CA
Added another slow-stick to my hanger after the last one went up in flames! This one has the new wing and after flying it briefly in the wind yesterday, I must say that I like it. My mods are a Axi 2212-26 motor, 11x4.7 prop, Electrifly SS-25 speed control, 11.1 1350mah 3 cell tenergy battery, two hitec HS-55 micro servos, carbon fiber push rods, carbon fiber elevator reinforcements, carbon fiber rudder reinforcements, micro hinges added to the elevator and rudder, and I clipped the wings. Here are a couple of pictures:
Greg
My rc stable including videos:
[link=http://web.mac.com/gunkel04/Site/Home.html]RC Mania...[/link]
Greg
#431
AZ
Tam, I tossed the plastic insert and used the small tube bend as the diheed, it is much flatter than with the insert. It really flys great and I can loop and even do a roll every once in a while. With the China hobby motor BESC and prop it will actually fly in higher winds than my other SS with the pronounced diheed.
So what I'm saying is if you want to take it out and make it flatter go ahead, it will fly just fine. maybe better!!!!!!
Bob, flying 3 mistakes high.
#432
Bob - when I've got the new fuses' finished I'll do full trials with thr 3 SS wings I have. Plus a 64in. balsa wing and an Easystar spare wing I have. I'll let everyone know the results - just need the weather.
#433
And the Lord God of all flying proclaimed it would rain for 40 days and 40 nights......Gee, what a great summer we had in Scotland that year!!!!!!!
#434
AZ
Tam, that 64 in and the easystar wings ought to make that SS float like a butterfly. Have fun, I can't wait to see your results.
#435
NM
I bob'ed the wings on my slow stick and I have to say, it made it 100% more flyable for me. Before, I never knew just what to expect when I flew. Sometimes it was just white knuckles time - other times it just flew perfectly. (I know, I'm blaming the plane and not myself ) But with the bob'ed wing its predictable and will do a 180 degree turn in a 10' circle. I'm now tempted to shorten the wing by cutting an inch off the front leading edge......
#437
NC
Bob, to post attachments, click "Reply" or "Quote" in the upper right corner of the post you want to reply to. That will bring up an edit box. At the bottom of the box there's a link that says "Click here to upload images and files!". Click that link.
#439
AZ
Gunkel, can you give me some info on the motor mount on your yellow SS? It looks simple and strong. Is it ? Are you able to bend it to the three degree down and to the right that helps the SS fly better? I have had an aluminum mount that looks somewhat like yours but it was too soft and bent very easy. It broke about the second time it bent. OH, and how did that clipped wing SS fly? I just cut one of my red SS wings like yours and will try to fly in the morning.
#440
NM
ORIGINAL: BobSkyFlynjunky
Two questions. Did you reinforce the cut wing?
How do I post pictures here? I just can't figure that out.
#441
CA
[link=http://www.hobby-lobby.com/10mm_stick_mount_for_outrunner_motors_2556_prd1.ht m]Stick mount[/link]
This is the 2nd mount that I own as I did not have long term luck with the balsa versions.
The plane fly's very good, responsive to inputs, but still floats like a SS should. In my opinion it handles the "breezes" better as well.
#442
AZ
Thanks for the info on the mount.
Well, today I took the short wing SS out. It was a slight bit windy and the currents up above were going 2 different ways. Anyway, the SS cut through the wind quite nicely and it really did float like a SS should. I wasn't able to put the 3 degrees down and to the right on this mount because I didn't have long enough screws to add the washers to do it. I had to do alot of trimming but it still flew great. It is much more manuverable and turns on a dime. I actually did some rolls using the upper winds to my advantage and was able to fly inverted with much success. It should really be great when I can get the 3 degree factor worked into the plane. A fellow at the flying field came up to me and said that he thought this SS had alerons and was suprized it didn't. That's it for now.
#443
AZ
OK, I'll try this again, got dropped when I tryed to post.
I flew the short wing SS again today and had the 3 degree down and to the right this time. Just one adjustment in the air and it was flying like a bird. I again could loop, roll, and do something called a hammer head. That's what the guys at the field called it. I'll take credit for it.......... It is a dream to fly. I'll try again to post some pics again of the SWSS.
#444
ID
Added a steerable tail wheel, found one at the LHS that was about the right size and home built the rest, ROG (short grass) at the local soccer field. Flew the plane a few times then threw on the ailerons, I won't be going back to 3-channel...ever!
#445
AZ
Zrat
How about giving us some details on your aileron setup. Let's see some pics. How did you set up the servos and did you use a Y harnes? How long?
I have 2 SS's and want to learn ailerons. Is it best to do on stock wing, or cut wing? What about the diheadrial?
#446
ID
BobSkyFlynjunky - Sorry, been offline for a while. This is my first SS, next one is still in the box. I built the plane based on the instructions, as well as I could interpret them. Put the 15deg dihedral in with epoxy and covered all surfaces with 3M clear packing tape. Flew it a couple of times but couldn't resit the urge to mod, I used two HS-55's (good luck with them so far and the LHS has them cheap). I used a 6" Y harness and a 6" servo extention to make wing removal easier, I'm running the 72Mhz receiver that came with my JR400S radio. I've seen several posts about NOT using dihedral with ailerons so I'm planning on a flat wing for better inverted control. I have the older SS with the aluminum fuse, the new one has thicker foam wing, not sure what the implications are there. I just cut out where the ailerons were molded into the wing, placed the servos so the linkage rod is directly inline with the throw, traced around the servos and cut holes in the wing, epoxied them in so they are flush with the top surface of the wing (recommend installing the servo arm before gluing in the servo). I haven't attempted a roll, I think a slow lumbering barrel roll at best with the dihedral in, I didn't clip the wing tips either, may try that before building up my other wing. The biggest gain for me was just how much control I have over the plane vs. rudder only for turning, I rarely use the rudder at all now. I didn't notice any appreciable drop in climb rate by adding the two servos, still playing with prop pitch. I've seen a few posts mention increasing the length of the aileron, might be able to get closer to a snap roll with more surface area. I'm no expert, just like to experiment and the SS slope gliders are only $25 at Hobbytown so I'm willing to try again if I mess it up. Here's the only good pic I have, I'll take a couple more and try to get them posted this weekend.
#447
ID
Correction, the 6" extension was for my ElectroStick. I'm using a 3" Y harness and 3" extension. Here a more pic's, I've got the email notify on so I'll watch for a reply...Zrat
#449
AZ
Thanks Zrat, looks like an easy mod. I have a cut wing and a stock wing. I'm still trying to decide which one to do the ailerons on. I will be getting an order from Hobby City in about a week with a motor combo and 4 servos, 2 of which will be used for the lucky SS wing that will be used in this mod. I am also bulding an E-Starter at this time and will be looking forward to using both the SS and ES as my aileron trainer planes.
I will really be interested to hear more on how your aileron SS flys.
Thanks Bob
Thanks Bob
#450
ZRat - thats how I modded my Stick, but with the ends of wing cut off by about 2in. each side. I didn't like it, it made very little difference to my plane and I went back to standard. Each to their own though. Godd luck man.
