Ohio 540
Ohio 540
Although in the UK I am building an OHIO 540 profile as I had the plan sent over to me. This is because profiles pretty much don't exist in this country.
What I am surprised to see is that the trailing edges of the elevators and ailerons are to be sanded to a point. This seems to go against what is needed for 3D flying in that all other models I've seen have square trailing edges.
Is this correct. Do I sand to a point or leave them square. All the pics of them on the OHIO website seem to be square??
Ohio 540
The triangle stock goes both on the trailing edge of the wing and leading edge of the aileron where it hindges. It actually says in the plans, sand the trailing edge of to a point.
My Feedback: (12)
Ohio 540
I had to pop the CD in and take a look...that does seem strange, but Mike has it like that on the ailerons and elevators.
With all due respect to Mike, I'm leaving mine squared off unless Mike pops in here in about the next day or so and tells me I'm about to make a grievous error by leaving them square.
Ohio 540
As far as I know, there are two ways the trailing edge of a control surface should be.
Either completely flat (no sanding, Chuck knows that's my favorite) and the other is sanding it or using tri-stock so it comes to a point. Both are OK as far as "flying" goes and neither will cause or contribute to flutter. The flat TE is usually considered to be better though and is MUCH more common.
I'd go with the flat simply because I think it looks better (see Chuck, there is a reason for it) and the strength. I can break a flat TE, don't even want to mess with a pointy one!
My Feedback: (12)
Ohio 540
I have to admit..enough sanding to get the ailerons/elevator to a point would be more than even I would like to do (it's WAY more than sanding the LE of a Sledge, for example! ) and I'm a firm believer in sanding. I'll take me chances with square...
Ohio 540
This is where I wish I had started this thread before the sanding process!!!
I have tapered the ailerons and elevators already now. Not to a total point but still tapered. Not and easy job at all and now wish I hadn't. I can see me re-building them at some point!!!!
Cheers for the reply's though chaps. The designer should read these and take note.
