Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
 Sledge aileron question >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 04-10-2004 | 08:22 PM
Default RE: Sledge aileron question
Hey georgec,
did Morris install the tube in your wing for the rx antenna? If not, like mine, how did you route it? I cut 1/2 inch off trailing edge only and angled the wood to fix ailerons. I will post pictures when my honey brings her digital cam back over.
Old 04-10-2004 | 08:48 PM
georgec's Avatar
No he didn't put a tube in the wing in mine either. What I did was drill a small hole in the bottom of wing then I drilled two holes through the side of the fuse abuot a 1/4 or 3/8 of a inch from the bottom. One hole right under the hole and one toward the back then just run your wire back and fourth through the holes. I had a Su Do Khoi done the same way works good. I hope you can understand what I am talking about was going to take a picture but you can't see the wire because it is through the blue part of the plane.
