Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
Morris Su Do Khoi Pull-Pull Cables Binding >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 07-01-2002 | 05:15 PM
Default Morris Su Do Khoi Pull-Pull Cables Binding
I have a Morris Su Do Khoi ARF. At the points where the pull-pull cables exit the fuselage, they bind. I've tried changing the angles by moving the control horns and the rudder and elevator servos to no avail. I've also tried various amounts of tension on the cables.
This is a problem because the rudder and elevator are very stiff and won't return to center when released. This makes it very difficult to control the plane - especially during high-alpha flying.
I'm using the stock plastic coated cable that came with the kit. I've considered using a more flexible kevlar cord, but I can't get it to thread through the tubes. Is there a trick to getting the cables right or to installing kevlar instead?
Old 07-01-2002 | 05:20 PM
Common problem on the Morris ARF's.
Solution,
Run the pull pull cables outside the fuse. Use small eyehooks to route the cables. No need for the yellow tube. Just run the cable.
Old 07-01-2002 | 05:31 PM
Ah, so simple. I knew there had to be an easy way to fix it.
Thanks!!!
Old 07-01-2002 | 05:35 PM
and don't forget. While they might not return to center on your work bench they will when flying through the sky~!
