Mr. Bad Boy Nova Bill
ON, CANADA
Hi William
The servo bay for the throttle servo is for a micro mini servo. Which servo so you use for the throttle. An HS81 is too big. Will a HS55 work OK? I was concerned about an HS55 lasting with the vibrations from the YS63. What have the rest of you guys used?
Thanks, Don
Thanks, Don
SC
RE: Mr. Bad Boy Nova Bill
I uses a hitec 55 on magnum 70 4 stroke BB. and i have over 50 flights with no problems!!! and i know william uses the 55 on his ys 63 with no problems so don't worry about using a 55!!
Mike
AKA Mr. Bad Boy--MadMikey
Mike
My Feedback: (24)
FL
Im using a 55 on mine too, I was dubioius at first but it works just fine an like Mikey said William has a boatload of time with his on a ys 63 an it held up fine. If you want just enlarge the hole an drop in an 81.
ON, CANADA
Thanks Gentlemen. Hooks, I was concerned about cutting away the material as it looks like heavy support ply on the rear edge of the fuse. I have a couple of HS81's and I would rather use what I have as long as it won't weaken the fuse. What are your thoughts?
Don
Don
NY
ORIGINAL: Basement Troll
Don
Don
Alot of people have been nervous about using the 55s. My plane had over 200 flights and now the servo is in the new plane and still fine.
www.carolina3d.com
TX
when i enlarged the hole for mine toward the back there is an ample amout of hard wood behind it as well. I actually epoxied some small blocks under the servos mounting holes so that i could open up the hole big enough that the wire would not be crimped, but still have some solid wood to screw into. It also flushed the back of the servo up with the fuse so it looks nice as well.
Basement sorry for throwing in a Q on your thread but I'm curious what pushrods the guys are using on the HS-55's? Do you guys also use a thinner piano wire to reduce vibration transfer?
NY
ORIGINAL: Spacey
On the YS you cannot use the stock CF rod. I use soft 2-56 rod on mine.
www.carolina3d.com
NY
Hey all,
We have announced the new name on the rename Carolina 3D threads.
Go here
http://www.rcuniverse.com/forum/m_37..._4/key_/tm.htm
http://www.rcuniverse.com/forum/m_3832308/tm.htm
Go here
