Suggestions for building bigger profile
My Feedback: (8)
MN
I bought an older Extra 300 Profile, with 80" wing span, and it has nice laser cut wing ribs. The instructions are sketchy but tolerable. I am to the point of putting in the push rods for the pull/pull and instructions say to drill through the fuse formers and install now after just completing the fuse assembly.
What would be a good thing to do for installation of the servo wires? I would like to almost cut the formers all the way through as the plane is sheeted, but it could lose some strength. Or, I could notch along the sides of the former and leave a gap in the sheeting and then run the servo wires along each side and just put a strip of covering over the gap in the sheeting?
Or, I could install something along side that I could just put the wiring into like a wire harness. Or I could skip the pull/pull and install or make a box for the pull/pull off the servo in the back.
Any suggestion from previous and experienced builders in this area would be appreciated.
My Feedback: (8)
MN
RE: Suggestions for building bigger profile
Sorry, I would have to use my regular camera and get a disc made, etc. The fuse is approx. Formers are 3/4 of an inch thick. The push rods for the pull/pull are supposed to have holes drilled through the rear formers and come out in front of the fuse trailing edge, like most models, and the front of the rods go into the rear of the center wing section which is permanently mounted. The wing ends are mounted with joiners and bolted. The kit is probably 8-9 years old. I know Aero-works has still sells a similar kit but it is an ARF I believe.
