Sig Fazer E-Conversion..............
G'Day All,
I was just wondering if anyone has successfully converted a Sig Fazer from Glow to EP???
I have had mine on the building board for quite a few years & if I get enthused enough i'd like to finish it but convert it to EP.
A comprehensive guide to this conversion would be much appreciated.
Cheers, Warren.
[email protected]
Cheers, Warren.
[email protected]
FL
RE: Sig Fazer E-Conversion..............
HEY WAZ, GOT A FAZER ME SELF HAVEN'T HEARD OF ANY E- CONVERSION BUT I WOULDN'T PUT IT PAST ANYBODY MAKING ONE I MADE THE LIGHTING HOLES ON MINE AND Y CHANGED THE TAIL FETHERS ON IT AT FIRTS IT DIDN'T HOVER CORRECTLY BUT I MADE A CHANGE ON IT VERY SIMPLE CHANGE AND NOW IT HOVERS NICELY I ALSO PUT MY TAIL SERVOS IN THE REAR NICE INVERTED HARRIERS & SUPER BAD FLAT SPINS KINDA HARD TO DO THE INVERTED FLAT SPINS THOUGH BUT WITH A SIMPLE FOUR CHANNEL RADIO WHAT MORE CAN I ASK FOR JEJE.YOU KNOW IF YOU PLAN ON MAKING YOURS ELECTRIC CHANGE THE PLY THAT GOES IN THE FRONT REMEMBER IT'S MDE FOR GAS ENGINES. GOOD LUCK GUY
Mine is still on the building board, I just checked on the box & the weight is stated as 3-1/2 to 4lbs.....................
Cheers, Warren.
Cheers, Warren.
A Hacker B50 13S, 80amp ESC and a 5S4P 6000 mAh for 4 1/2 to 5 pounds. I can look up some Less Expensive combinations for you. It would take me a day or so. Depending upon what your looking for in performance, you may be able to get away with a smaller lipo. This would not be a cheap setup, but the combo would fit in a couple of aerobatic planes I can think of. Build Lite!!
Cheers,
Tim Folk
Cheers,
Tim Folk
