weird stall ???
weird stall ???
Hey All, I was out putting my fun 51 through the paces and went to try an elevator. Here's what it did, got it to slow WAY down as I fed elevator in and it just about stopped in midair. Right before it came to a halt the crazy thing started this weird bounce. It looked like it was on a wash board road.
Any ideas????
should I add any thing to it, besides a little more power maybe. Or more throw in the elevator???
Thanks!!!
Kevin
Any ideas????
Thanks!!!
Kevin
weird stall ???
"Right before it came to a halt the crazy thing started this weird bounce. It looked like it was on a wash board road."
Like it stops flying for a second, then flies again, then quits again, and on and on like that?
weird stall ???
I read my radio wrong before, it has 70% on the airbrake feature. That might be too much, Im still new to this type of plane. It only has 7 flights on it....other than this, it flys great! Not to bad for a 45 dollar plane...
weird stall ???
I read over your first post again and saw it's the Fun 51...First time I read it I got the idea it was a Sledge for some reason.
The Fun 51 will not do an Elevator... It will just do what you described. It will look great in the wind though!
I got about 400 flights in on my Extra Special (basically the same plane) and I tried an elevator everytime I flew it! I just got used to the up and down thing...It was still fun.
More elevator and more rearward CG will help, but physical changes to the design are needed for a really smooth and stable drop like you want.
Other than that, it's a fun plane! It will harrier, but takes just the right entry and a higher than usual nose high attitude. You try a flat spin yet? My Extra Special would just about do a climbing inverted flat spin... KE spins are dang quick too!
weird stall ???
yep looks like a dolphin.
Wind seems like a daily thing out here...I ended up with the extra version from a friend in our club that didnt want it anymore. Still need a motor and radio gear to get it going.
Talk about flat spin...its almost a blur!!! I havent mastered a climbing flat spin yet, still working on it. KE's are real easy, from one end of the field to the other. It has a tendance to pull to the belly, but easy to mix in a little elevator to compensate...
These things are way to much fun!!! Just wished there were more people here that flew them.
