Flaperons and 3D
UT
Flaperons and 3D
Quick question thats been covered to death Im sure, but I noticed my radios have the ability to use flaperon mixing. Now I wont be taking the dazzler apart, but I would like a brief explanation of how it works if one servo is plugged onto slot 2 and the other one in slot 6. This being the case, does that mean I can only run flaperons and not fly in normal configuration or switch back and fourth? Im a bit confused with this one.
I have the JR 632 computer radios by the way.
My Feedback: (13)
AK
Flaperons and 3D
You are right on setting up flapperons. You put the right aileron in the aileron channel and the left aileron in Aux1. You mix them so that they either act as flaps (Both ailerons go down like flaps but still move up and down like ailerons.) The most common application that I know of is for 3D style flying. You make both ailerons go up with up elevator (flapperon). And make both ailerons go down with down elevator (Sorta Inverted flapperon). It helps keep the wing steady in High alpha manuvers. It can alson help tame down an airplane the tends to snap at slow speed. Hope this helps. Below is some good setup info for the JR radio that I copied from a post and has really helped me out.
System Set-Up Mode
To start with we will open a clear model, so press and hold the up and down keys together and flip the power switch on and then release the up and down keys. Press the + and – keys to go into model select. Press the + key until you get to a clear model. Then press the up key twice to get to the model type. To get to the correct type, press the + key to get to ACRO, if it is not already in ACRO mode. Next you will press the up key to model reset. Press CLR so that it will restore the system to factory defaults. Press the up key to select the modulation of the system. Here you will use the + and – keys to set this to the desired modulation. Press the up key twice, to set the wing type selection. Press the + key to set this to mix wing FLAPERON. Then you can press the up key till you get to the name selection, and re-name the model.
At this point we have set up the system mode for our plane. One important thing to note is the flaperon set-up that we put into the wing type selection. This feature mixes the aileron channel with the aux 1 or channel six, so that they will both work as ailerons, and we can set them up to work as flaps as well. Plug the right aileron in to channel 2 and the left into channel 6.
Function Mode
Next we will set up the function mode of transmitter. If you are still in the system mode, just press the up and down keys together twice, or turn the radio off and back on, and press the up and down keys together again. This will get you into the function mode.
Dual Rate and Exponential Set-Up
Now that we are in the function mode, it brings you to the dual rate set-up. You can set these to your desired amounts. Press the channel key to select the channel, and the + and – keys to set the rates. I would set up the high rate at 100% and the low rate between 50% and 75% for the elevator and aileron, and between 60% and 80% for the rudder. Next press the select key to get to the expo set up for each channel, and use the + and – keys to set the values. You can set various values for each rate. I use around 50% expo on high rate elevator and aileron and between 20% and 50% on high rate rudder. I would use around 20% to 30% on low rate elevator and aileron, and 10% to 15% on low rate aileron.
Travel Adjustment
Next we will set up the travel adjustments, so press the up key till you get to the screen where it says TRVL ADJ. in at the top left hand side of the screen. Your manual gives a good description of how to adjust these. Press the select key to get to the second set of 4 channels for adjusting the travel. For a full 3D plane, I would set the travel adjustments to 150% on the control surface channels including aux 1 and aux 2 which in the travel adjustment will be labeled FLAP and SPOI. This will help enable the large control surface throws using the highest mechanical advantage possible, as you are using the full movement of the servo. Then set your distances out on the servo arm to the linkage as small as possible and the control horn to the linkage to as large as possible, and still maintain 40 to 45 degrees travel on the surfaces. Follow the planes recommendations for the linkage set up. This is very crucial, as an incorrect set up will lead to flutter.
Aileron Differential
Next press the up key till you get to DIFFEREN. This is where you will set-up the differential in the ailerons. You will use this to help the plane roll more axially. This feature makes the aileron go further up, than down. This is necessary due to differences in lift and drag generated by the up and down going ailerons, creating a yawing moment on the plane. Having the up going aileron going further up than down, minimizes the effect. The amount required will vary plane by plane. If the manual for the plane gives a guideline for the amount of differential follow it. If it does not give a guideline, start out with 5% to 10%, and adjust after flying to improve the roll characteristics.
Completion of Aileron Set-Up
Now we need to remove the flap pot from operating the ailerons as flaps. If you like having this ability, you can continue to the next paragraph. Press the up key till the screen says FLAP POT. Press the CLR button until this says POT. INH. This will eliminate the pot function.
Dual Elevator Servo Set-Up
Now we will set up the elevators, so that we will have channels 3 and 7 working together. You will plug the right elevator into channel 3, and the left elevator into channel 7. Press the up key till you get to mix 5 or 6. We will use 5 or 6, as they are including mixes, meaning the elevator trim lever will operate both channels. If you do this mix on any other mix, the elevator trim will not work the second channel. Press the + key and change the first channel until it says elev. Press the channel key over to the second channel. Press the – key to change the second channel to SPOI. Make sure that beside SW: it says ON. If not, press the select key till the arrow points at SW, and press the + key to make this say ON. Press the select key till the arrow points at Rate: and make the percentage 100% by pressing the + key. Then move the elevator stick, and the arrow will move to the 0% in one direction of movement. Make this 100% also with the + key. Now we have the elevator working on both channels, but the aux 2 knob will operate the second channel. To eliminate this, will use another mix. For this mix, I would use mix 3. Press the DN key to get to this mix. Once at the mix, press the + key till it says SPOI for the first channel. Press the channel key so that the second channel is underlined. Press the + key and make the second channel is SPOI. Then press the select key till the arrow points at Rate. Press the – key till it says -100%. Then rotate the aux 2 knob, which is on the top left hand side. Rotate this until the points at the 0%. Press the – key till it says –100% also. This completes the set up of the elevators.
At this point, we have a fully functional set-up, but there are still lots of features you can add. You will of course need to set up your sub trims, servo reversing, and travel adjustments as required. Keep in mind that the lower sub trim value you use, for the most part, the better off you will be when trying to use large travels. If you use too much sub trim, your servos will reach the end of their movement before the surface moves very far.
Flaperon/Spoileron Set-Up
For a 3D set-up, we will set up the spoilerons. One good way to set up the spoilerons for harriers and elevator maneuvers, is to mix elevator to flap. An easy way to do this mix is with the elevator flap mix, which will work with the flap mix switch. Press the up key till it says ELEV-FLAP MIX in the top line. This will set it up so that they will work with the flap mix switch in the up position. Just flip the switch up, push down elevator, and press the – key until with down elevator the ailerons both go down. If they go up, press the + key instead of the – key. I use 100% in this mix to help keep the wings from rocking in an elevator or harrier. Now pull up elevator and press the – key until with the up elevator, both ailerons go up. If they go down, press the + instead of the – key. Again, I use 100% here. If you would like to have this on a different switch, or would like to have this function work with the spoilerons be active with the switch in the down or LAND position, follow the mix below. Lets set this up in mix 4. Press the up key till you get this mix. Now press the + key till the first channel says elev. Press the channel key so that the second channel is underlined. Next, you will press the select key until the arrow points at SW. You can put this on a few different switches, but lets set this up on the flap mix switch. Press the + key until it says LAND. This will activate when the switch is in the down position. Now we will press the select key to get back to where the arrow points at Rate. If it says OFF, move the flap switch down to the land position. Pull up elevator, and make the value –100% with the – key. Now push down elevator, and make the value –100% again. This should make the ailerons go up with up elevator and vice versa. If they go opposite of this, change the –100% values to + 100% to reverse it. Of course if you want to set-up flaperons instead of spoilerons you would make the ailerons go down with up elevator and vice versa.
Smoke system Set-Up
Another option that can be used is a smoke system. An easy set up for an electronic smoke system if one is to be used, is to plug the smoke into the gear channel and use the gear switch to turn it on and off.
Hope this helps.
System Set-Up Mode
Function Mode
Travel Adjustment
Smoke system Set-Up
Hope this helps.
UT
Flaperons and 3D
WOW
Way more then I ever expected. Thank you very much!!
I am thinking of setting up my next aircraft with this option, cause it sounds like I have the choice to run normal or flip a switch and have some extra control. I printed your response to keep on hand.
