Ex-treme 330 ARF instruction booklet
Got me the CG xtreme 330.
My first profile. Man i was excited, so excited that i didn't notice that there was NO installation guide in the box, DAMN!!!
Does anyone know where i can find the manual on the web?
I would appreciate some tips on the installation of the wing (do i just glue it with 30 min epoxy to the fuselage?) and how does the radio gear fit into the wing (batts, reciever, aileron en trottle servo's). Some pics could be very helpfull ;-)
Did you guys use the included CA hinges or replaced them with "real" ones?
Can i use standard servo's on all surfaces or do i need stronger ones?
THX & GREETZ, Gaaaz (Belgium)
Fortunately assembly is pretty easy.
Just mark the wing and stab where it meets the fuselage. Trim the covering so you can glue wood to wood on the stab and wing. be carefull to make everthing centered and square to the fuselage. The radio gear goes in the wing. The aieleron pushrods poke thru the skin behind the hatches, CG should be 5 - 5 1/4 behind LE to start.
If you have built an ARF before you can probably do fine without the manual.
If not, PM your address and i will mail you mine.
