OMP 540 where to put switch
Seems like a simple question, but I'm curious what you did. I have the hatches on the top of the wing. Where should I put the switch (and I guess a charger jack is essential as well)?
My Feedback: (14)
Same here, 'cept I didn't have a combo switch. I cut a small notch in the hatch and let the charge jack hang out in the breeze. When I get back to the LHS, I'm gonna get a combo stitch...
Somewhere easy to get to, but hard to knock by accident.
On my last profile I had it mounted right on top of the wing in the middle of the left side center sheeting...
GA
I have a separate charge jack and the switch mounted on the right hatch. The jack and switch are side by side and run parallel with the fuse. I mounted the switch so that the off side is facing forward.
I dont have a switch. I just have the two plugs sticking out. Plug them together and its on. When there unpluged i just hook my volt meter up to check.
