RCU Forums
-   Profile and Fun Flying Planes (https://www.rcuniverse.com/forum/profile-fun-flying-planes-105/)
-   -   Pull-Pull Systems (https://www.rcuniverse.com/forum/profile-fun-flying-planes-105/81044-pull-pull-systems.html)
stevezero 03-20-2002 04:24 PM
Pull-Pull Systems
1 Attachment(s)
and another view of the tail. There are actually small pieces of teflon tubing inside the pushrod tubes where they exit the fuse.
Shortman 03-21-2002 03:46 AM
Pull-Pull Systems
i just dont get how a elevator pull pull would work without the servo being mounted sideways???
stevezero 03-21-2002 02:15 PM
Pull-Pull Systems
Shortman, Look at the fuselage pic above. The two wire connection is the rudder. The 4 wire connection is the elevator. All 4 wires come together inside the fuse near the wing. The wires work just as a pushrod works with a servo mounted upright. As long as there isnt a severe bend in them, they move according to the geometry of the motion of the servo. Just look at it as a rudder p/p on its side at the surface, and normal at the servo. There is absolutely no slop in this arrangement, and it does allow you the ability to still have some elevator control in the event of one wire breaking. The 4 wire method only works on split elevators. It would be overkill to have it on a single surface elevator.
BigBird1 03-21-2002 03:01 PM
Pull-Pull Systems
Try fishing line...
Fire Line or Ripcord...(Copolimer=Kevlar)
150 yard spool isn't that expensive and ya don't have to worry about inteference..comes in a lot of different poundage.
Works great for tail struts, pull pull, etc..
Someone11-RCU 03-23-2002 02:54 AM
Pull-Pull Systems
How do you connect the wire to clevis to servo?
Thanks-Brian
jmulder 03-23-2002 03:07 AM
Pull-Pull Systems
I take a pushrod and cut off the threaded end and make a small loop in it and then just thread it right into the clevis........
Razor_Sharp 03-23-2002 04:52 AM
pull-pull
1 Attachment(s)
The lightest way to do pull-pull is with the least amount of hardware. I use K&S #49 Kevlar from Tower Hobbies. It costs 2.69 for about 100 ft. I tie it directly through the servo horn and secure it with a drop of CA. On the rudder end I used a short peice of 2 56 rod with a loop in the end like jmulder. Very strong and light and CHEAP.
Razor_Sharp 03-23-2002 04:54 AM
More Pull-Pull
1 Attachment(s)
Rudder end
Someone11-RCU 03-23-2002 06:15 AM
Pull-Pull Systems
Does this hold well Razor Sharp? To me it would seem safer to just use a clevis or something. Have you had any problems with your setup?
Thanks-Brian
Razor_Sharp 03-24-2002 05:08 PM
Pull-Pull
Not a problem yet. This is how Don Incoll does all of his wasps.
rmm 09-22-2002 03:12 AM
Pull-Pull Systems
Steve,
I looke around today in walmart, sporting stores to get a crimping tool, steel leader and sleeves. No luck!
Does anybody know where I can get this stuff in the area of Princeton? Otherwise I need to mailorder - any sugestions?
Rainer
PaulSwany 09-23-2002 02:53 PM
Pull-Pull Systems
Try a Bass-Pro shop....
stevezero 09-23-2002 06:26 PM
Pull-Pull Systems
The further you go inland, the harder its going to be to find this stuff at walmart. Bass Pro shops, like Paul Said, is going to be a good bet. You could even call a local fishing tackle shop in your town and ask them. You'd stay local, and keep a small businessman afloat.
