Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Help On Speed Props
Old 07-07-2002 | 03:44 AM
Default Help On Speed Props
YES CAN ANYBODY PLEASE TELL ME IF YALL CAN FIND SOME CARBON FIBER PROPS FOR A Q500 MVVS.40, THE SIZES ARE FROM THE ODD 8SIZES LIKE 8.75x6.75&^ FROM THERE. THANKS
Old 07-07-2002 | 04:21 AM
Default Props
Howdy, go to www.APCProp.com and you will find all the Speed Props you can handle
BV
Old 07-07-2002 | 05:18 AM
i know that but i want carbon fiber props
Old 07-07-2002 | 03:21 PM
Default C/F Props
APC has them,,, as a matter of Fact, he's the only one that has them! Now that I think about it,,, his C/F props are for engines that are able to turn 22,000+
For my Q500 MVVS,,, I have found that the APC 8.8x9.25 with the short pipe and long header works the best for me out here in Sunny So. Cal
BV
Old 07-07-2002 | 03:28 PM
YEAH BUT THE ONLY WAY I CAN GET MY V-VECTOR TO GO OVER 208MPH IS TO HAVE ONE C/F PROP BUT THE PROP U SAID WOULD THAT BE A SPEED PROP CAUZ THE GUY IN HOUSTIN THAT WAS THE MAKER OF THE & SELLS THE ROSSIE/MVVS ENGINES/ Q500 PLANE SAID THAT 7 OUT 10 THE MVVS WOULD WIN . O HE ALSO SAID TO USE A 9x7 APC PROP FOR SPEED.
THANKS YOU FOR URE TIME
Old 07-07-2002 | 04:00 PM
O ALMOST 99.9% OF ALL AIRPLANES HAVE A DIFFERENT PROPS FOR SPEED. I HAVE A TTPRO .46
DONT MAKE FUN OF ITS VERY VERY HARD TO BE THE QUALITY
& RELIABLEBILITY & PERFORMANE. I HAVE A SCANNER A LOW WING SPORT PLANE TRAINER AND MY DAD BOUGHT A RAIDARGUN,
I BOUGHT A PERFORMANECE SPEIC. PIPE & A 10x6 APC PROP
IS NOT FOR SPEED PROP FOR MY SCANNER . O & ITS MADE FORM PHINOIX MODLES, ANYWAY FOR A SPEED PROP ITS A 10x8 APC
& MY TOP SPEED IS 116 MPH & THATS FAST FOR A LOW WING SPORT TRAINER.
Old 07-07-2002 | 04:03 PM
208 mph with a V-Vector and a MVVS .40...............
If you could hit 160 mph with any prop I would be amazed.
I would have liked to see the Dive and Tailwind of a quickee that was going 208.
Old 07-07-2002 | 04:06 PM
Old 07-07-2002 | 04:12 PM
IT SAYS IF U GO TO MORRIS HOBBIES UNDER GOOGLE SEARCH.
Old 07-07-2002 | 05:21 PM
Banned
I would recommend that you contact Morris Hobbies so they can give you the details on the equipment needed to go 200+ with a V-Vector.
The props you are probably looking for are at Supercool Racing Propellers
Old 07-07-2002 | 07:22 PM
My Feedback: (10)
An MVVS 40 will not take a quickee to over 200mph. I think this type of plane could be clocked at 208mph in a DIVE with a QM40, or FAI motor with really good props and pipes, like that of supercool. Typical quickee speeds are in the 130-170mph range, depending on motor. I believe the 7 out of 10 referred to is in a MVVS vs Rossi debate. A Nelson, or Dub Jett are two typical quickee motors.
Michael
Old 07-07-2002 | 07:33 PM
HEY I KNOW THE GUY THAT HAS A Q40 MVVS & THE V-VECTOR & SO DOES MY DAD I WAZ THERE WHEN THEY CLOCK IT. THEY USED A C/F PROP IT WUZ AN ODD 8 SIZE PROP,& YES IT WAS IN A DIVE & DID U GO TO MORRIS HOBBIS? GO UNDER KITS & GO TO THE 2ND PAGE CLICK ON IT. & ITS ACTTUAL SPEED WAZ 211 MPH SO
HA
KEVIN
Old 07-07-2002 | 07:46 PM
My Feedback: (10)
Kevin-
I'm not sure what you are trying to prove. If you know what motor it was and equipment, then fine. However, I would find out exactly what prop you need. There are probably only a few places to get them - APC and Supercool have been suggested already. You might want to try them. However, unless I am mistaken, no MVVS that I know of puts out the power of a Nelson, or similar. Having the right prop doesn't always equal speed. You need the motor to turn it.
Michael
Old 07-07-2002 | 07:57 PM
THANKS BUT IT SAID THAT AT MORRIS HOBBIES.COM
THAT THE Q40 MVVS PUTS OUT 23,000RPM LOOK IF U DONT
BELEAVE ME. I KNOW FOR A FACT THAT IT CAN KEEP UP WITH
A NELSON Q40. LOL BUT MY DREAM ENGINE IS THAT NELSON 40 FIRE.
KEVIN
Old 07-07-2002 | 08:09 PM
My Feedback: (10)
Yes, the web site may have said that it went 208.... But note that it does not say with what equipment! Only says clocked at 208mph... Advertising can lead you to believe things that are not necessarily true. Yes, I would not doubt that the plane has been clocked at 208mph. However, they are trying to sell the plane by saying it is fast and they do not mention with what particular motor.
MVVS's are great motors. I'm not convinced that they are as powerful as nelsons, but, like I said, they could surprise me.
Take a look at this link... One person bought the motor and has not been able to get it to 21,000 rpm. Looks like you?
http://morrishobbies.com/product_rev...215da0ccabbea0
Like I said, advertising is funny sometimes. You probably can make it turn 22,000 with a 7" diameter, 6" pitch prop... They don't tell you how you how they got the 22,000 rpm. For $170, if this turned props and rpms as good as it seems the Jetts and Nelsons wouldn't be selling as good as they are.
Michael
Old 07-07-2002 | 11:22 PM
HEY IN MY O-PIN-INE TO PEAK THE PERFORMANCE TO A MVVS Q40
IS TO USE TOP OF THE LINE FULE 15%,SHIM THE HEAD, TUNE ON THE FACTORY PIPE/THEN GET A MACS HEADER PIPE , USE A ROSSIE GLOW PLUG R7,OR R8, ONE BLADED PROP/A BOLLY PRODUCTS SHOW PROP,OR A C/F PROP, BORE THE PORT TIMEING FOR MORE FULE /TO ACT IT LIKE A MINI TUNE PIPE,"O" USE A INSULATING FULE TANK/ USE THE DRI ICE TO CHILL THE FULE/MAY GAINE 500/RPM, I GUESS DONT REPLACE THE BEARING CAUSE IT ARE READY HAS SPEED BEARINGS, UMM.........................CAN'T THING OF ANY THING ELSE COULD U TELL ME "PLEASE".
THANKS KEVIN
Old 07-07-2002 | 11:36 PM
My Feedback: (10)
At that point, you might just buy a Nelson or Dub Jett.
Old 07-08-2002 | 12:08 AM
JohnBuckner's Avatar
Thanks for the entertainment Mr. Speedman, see you at the races!
John
By the way don,t forget your 'speed prop' whatever that may be.
Old 07-08-2002 | 01:01 AM
ALSO MY PEAK RPM IS 18,530. ALSO IF I' VE ONLY HAD IT THROUGHT 2.5GAL. "O" AND IM RUNNING A APC 9x6 WITH RICH'S BREW 15%/ WITH A SHIMED HEAD.
Old 07-08-2002 | 02:16 PM
Kevin -
Sounds like you have obtained a good amount of knowledge towards making good horsepower with a MVVS motor. The thing I need clarification on, is.... if these engines are so good or at least comparable to the Nelson or Jett.... then why haven't I every seen one on the front of a plane? Now my knowledge may be limited to my 5 1/2 years of experience and I certainly have many things to learn, but I would think that for the price mentioned to buy a MVVS motor, that would be a no brainer?
We are also always looking for new young guys to join our hobby of racing, expecially guys that like to go fast !! If you truely believe that your planes are fast (which I'm sure they are) is find a race in yur area and attend. Who knows, you may enjoy it.
Fuel...not fule
Randy Bridge
Team JR
Old 07-08-2002 | 04:21 PM
THANK YOU IM ABOUT 75% DONE ON MY V-VECTOR.
Um........I've been only about 2.5years. I live in L.A.
Louisiana/ Boissier,City im planning to race in Houstin
teaxs.talkin about fast airplanes mi dad has a Hobbico
Spectrumand he has a mvvs.77 runing a shimed head 15% Riches Brew, running a 10x10 APC prop with long tune pipe
@13,280rpm.wich =s to 125MPH.
THANKS KEVIN
Old 07-08-2002 | 04:25 PM
O ALSO THE REASON WHY MVVS IS ABOUT 25% USED IN RACEING IS CAUSE PEOPLE NEED TO GIVE THEM AT CHANCE. & IM ONLY 15 YEARS OLD.
Old 07-08-2002 | 04:32 PM
Randy Smith's Avatar
Speedman wrote:
"HEY I KNOW THE GUY THAT HAS A Q40 MVVS & THE V-VECTOR & SO DOES MY DAD I WAZ THERE WHEN THEY CLOCK IT. THEY USED A C/F PROP IT WUZ AN ODD 8 SIZE PROP,& YES IT WAS IN A DIVE & DID U GO TO MORRIS HOBBIS? GO UNDER KITS & GO TO THE 2ND PAGE CLICK ON IT. & ITS ACTTUAL SPEED WAZ 211 MPH SO
HA"
Me thinks something is lost in the translation here......
In one of his posts, I think Mr. Speedman is using the term Q40 to mean 'Quickie 40 engine' when the rest of us know Q40 to mean Quarter Midget 40. I think there's some comparison of apples and oranges going on here.
The bottom line is speed clocked in a dive means Diddly-Squat ! You must properly radar gun a model in level flight upwind and downwind in a series of readings and determine an average.
My friggin' car keys will do 200 mph in a dive from 1000'
Put yer MVVS on the course with three other guys and let's find out what speed is.
Randy S.
Old 07-08-2002 | 04:50 PM
Now that's the funniest thing I've heard all day. You've got some awfully fast car keys. Randy, I'm buying you a beer for that one !!
And your so right, radar doesn't mean anything unless used properly. Many passes upwind and downwind...and LEVEL...
Randy Bridge
Team JR
Old 07-08-2002 | 05:08 PM
Thanks, you better buy me two.
Two American beers equals one Canadian. Too bad the dollar exchange doesn't work the same way.
You may submit the beer to Ed Smith or Roy Andrassy at the Muncie Nats. I'll get the beer from them when they get home..... ya right !!
I am (Molson) Canadian !
Randy S.
