K&B . .61 RC
RE: K&B . .61 RC
You will need 2 prop nuts. Jam the two nuts together, and then use the "locked" nuts to back the stud out. If that doesn't work,
you might need to weld the nut to the stud. If you are still unable to get it out, send it to Clerance Lee. Good Luck, Greg
