JR tansmitters
Old 01-30-2011 | 02:18 PM
Hircflyer's Avatar
Default JR tansmitters
Anyone a source for wiring diagrams for JR transmitters???
Old 01-30-2011 | 02:25 PM
LargeScale88's Avatar
Default RE: JR tansmitters
Years ago, the FM manuals (the ones I got anyway) came with diagrams. If not, then I suggest talking to JR.
Are you doing internal work? I think there is a 3rd class radio license requirment to open the radio up. Just thought you wanted to know.
Jason
Old 01-30-2011 | 04:34 PM
My Feedback: (25)
Jason
Jason, if you had to have a 3rd class Radio License to open it up, then there are a lot of folks in trouble for taking the back cover off to tighten the gimbles.
Hircflyer: what are you wanting to do on the inside anyway?
Jon
Old 01-30-2011 | 08:17 PM
Hircflyer's Avatar
ORIGINAL: Jonathan Ott
Jason
Jon
Well' I have several old non computer type JR FM transmitters which are just hanging on my shop wall. I don't use them any more as I have 2 JR 9303 transmitters. Hobby king sells a 2.4 kit to install on those old type transmitters. I thought for about 15 dollars it be worth a try to upgrade these old transmitters. Figured it be good for a small park fliers. I have several grandsons who could put them to good use
Only has 3 connections to be made...one to the transmitter battery lead, second to ppm output, third to ground....
I can find the power and the ground but having trouble locating the ppm output
I believe it would be the lead to the ant.
http://hobbyking.com/hobbyking/store...dProduct=14353
Old 01-31-2011 | 05:25 PM
My Feedback: (22)
Those might be the outputs for the trainer cord?
Old 02-01-2011 | 12:15 PM
ORIGINAL: Hircflyer
Jason
Jon
NOT the lead to the antenna, that is RF output. You need the wire going from the encoder to the rf deck.
Old 02-01-2011 | 12:51 PM
Hircflyer's Avatar
Ok, thanks I will look for that!
Old 02-02-2011 | 11:55 AM
Jason
Jon
My bad. I meant to fiddle around with the electronics. I've taken the back off several times to tighten those.
Jason
Old 02-05-2011 | 08:12 AM
My Feedback: (25)
Old 02-05-2011 | 12:03 PM
wouldnt needing a license depend on the power out put?
Old 05-10-2011 | 06:28 AM
Hircflyer's Avatar
Wll believe or not finally got around to the modification....easy as pie, found all three wires I was looking on the encoder board soldered up kit part from HK ....removed the ant. Drilled a couple holes installed new ant. And presto full function 2.4 transmitter with
All The bells and whistles the JR 642 transmitter had, neat!
Only one thing tho I thought I had screwed up something because when I tried it with an old JR 537 servo I had it didn't work, However! When used with a new digital servo WORKS great! Had great range.
What deal less than 30 bucks you get a full function 2.4 set....with a transmitter I was going to trash.
ORIGINAL: deadstick8409
ORIGINAL: Hircflyer
Jason
Jon
