Engine Mount
Old 12-14-2011 | 09:15 PM
Maxdog.vf213's Avatar
Default Engine Mount
Hey Gang...
Ok so Ijust got anAMAZING but pre ownedRV-4 with a70" Wingtoday and Iwas going to put My OS75 in there and asIm mounting it Irealize Iam at the very end of the mount and the prop shaft is to short, The prop hub is setlike 3 1/4" behind theCowl opening, Measuring from the firewall to opening ofcowland adding a bit of room for clearence its like a hair over 6"!!So Icall My hobby shop and big shocker they are all scratching their heads..
Imean can Ijust add more wood between the mount and the firewall, Will that be strong enough?
Anyways, anyone else know where Ican get a long mount, whats its called, who makes it.. ETC..
Thanks All..
Max.</p>
Old 12-14-2011 | 09:54 PM
My Feedback: (9)
Default RE: Engine Mount
You will probably need to make a plywood box & mount it to the firewall first & then the motor mount . Max H.
Old 12-14-2011 | 09:55 PM
Thats what I figured.. Thanks..
Old 12-15-2011 | 08:58 AM
scale only 4 me's Avatar
My Feedback: (158)
That seams odd to have to shim a mount out that far,, I'd like to see a pic of what you have there
You could also just buy or make some stand offs,, but an extra 3 1/2" is alot
Old 12-15-2011 | 09:33 AM
I think you must have mismeasured somewhere. A 60 to 75 motor and mount will be more in the order of 5 inches or more from the back of mount to the from of prop hub. However, probably easier than building a box extension on your firewall would be to use standoffs. Many sizes are available or if you are good at cutting thick wall tubing you can make your own. Here is just one of the many sizes that Tower sells, http://www3.towerhobbies.com/cgi-bin...&I=LXYUT3&P=ML .
Old 12-15-2011 | 09:47 AM
Jetdesign's Avatar
My Feedback: (8)
yeah, let us know the model/manufacturer, etc. sounds like something is missing.
Old 12-15-2011 | 10:55 AM
I have the OS .75 AX mounted in the GP RV-4 using the engine mount that came with the plane. It fits fine. The mount is this one:
http://www3.towerhobbies.com/cgi-bin...&I=LXJ773&P=SM
Bruce
Old 12-15-2011 | 11:13 AM
Here is it. Not sure Idid anything wring but man am Igetting frustrated. Bought her used so I wouldnt have to build anything so Ican be flying by the weekend but all this "surgery" Ihave to do is killin Me
ID:	1700360   Click image for larger version
ID:	1700361   Click image for larger version
Old 12-15-2011 | 11:19 AM
ORIGINAL: landeck
http://www3.towerhobbies.com/cgi-bin...XJ773&amp;P=SM
Bruce
Ijust bought that one but the engine width is to narrow on Mine..
Old 12-15-2011 | 11:20 AM
Your problem is that that is not the one that originally comes with the plane. It is too short. Use the one I pointed to above.
Bruce
Old 12-15-2011 | 11:21 AM
The width of the mount is adjustable. The OS .75 fits perfectly.
Bruce
Old 12-15-2011 | 12:43 PM
My Feedback: (158)
Looks like Bruce is right,,look at page 15 & 21 of the manual,, the mount is much longer
http://manuals.hobbico.com/gpm/gpma1357-manual.pdf
Old 12-15-2011 | 07:10 PM
Yes, as Istated Idid buy the bigger one after Inoticed the standardone from My old plane didnt fit but it is not perfect size so maybe mine was molded wrong or something.. Had to use a clamp and drill the holes with the engine on and so on.. Needless to say it is on and now Iam having the HORRIBLEtask of cutting the Cowling for the huge muffler that sits down below.. One bad thing about buying a pre owned plane but Ijust had to have this plane and I hate to build, in the worst way..
