 Fuel proof paint? >
Fuel proof paint?
Fuel proof paint?
Old 04-16-2012 | 09:55 AM
My Feedback: (8)
Default Fuel proof paint?
I had to do an impromptu repair on a cowl and need the plane this weekend for an event. Is there some version of hardware store paint that is fuelproof or at least will last for a few flights? I am not concerned with color, texture or finish just that it will cover the repaired area and not flake or wear off right away. I do not have a hobby store close by and don't know that there is enough time to order and get some here.
Any thoughts?
Old 04-16-2012 | 10:09 AM
Default RE: Fuel proof paint?
Rustoleum - if it says Fights Rust. Only basic colors- not clear.
Paul
Old 04-16-2012 | 04:59 PM
Some of the polyurethane cans are fuel resistant, not proof. They are better if they can cure for a couple of days to a week. As long as you do not soak it with fuel, clean it up after the flight with alcohol you should be OK.
Do you have a automotive paint store around? They might be able to mix up a 2 part clear and pout it in a spray can?
Buzz.
Old 04-16-2012 | 07:20 PM
My Feedback: (8)
Thanks guys.
Old 04-16-2012 | 08:43 PM
Do you want spray? Look at appliance paints. They are generally epoxy.
