Slowing Retracts
My Feedback: (10)
Slowing Retracts
I had posted this question before in regards to slowing the extension and retraction of my Pnuematic retracts, got some great info and I was successful to a certain degree by using airline retrictors and adjusting the valve to slow the retracts down; a quick question, right now I use a Hitec Digital servo to pull open and close the Robarts Red adjustable Retract valve; the servo does this qucikly, since this is a Hitec Digital Servo and I have a Hitec Digital Servo programmer, if I programmed the servo to operate as slow as possible, do you think this would slow the operation of the retracts even more, which is what I am trying to do?
My Feedback: (10)
RE: Slowing Retracts
Thanks for the replys, wasn't sure if someone else had tried this or not, got the idea when I was watering some plants the other day and I only wanted a slow flow of water and to do this I opened the valve up slowly; so I thought! what if the retract servo opened up slower? anyways, the more I thought about it, I figured slowing the servo down wouldn't do it afterall, because its the same amount of air pressure weather you open the valve fast or slow; saves me undoing a bunch of stuff to program the servo, as I mentioned my set up seems to be working just fine, I may try the wheel collars on the lines going to the tail wheel gear because they still slam up and down.
