using rudder
Old 05-06-2013 | 06:42 AM
  #51
Default RE: using rudder
so many mixed reviews ?
why is this thread so long
Old 05-06-2013 | 03:02 PM
  #52
sensei's Avatar
ORIGINAL: Ron Stahl
Our chief instructor now insists on mixing rudder from the aileron input on every plane he flies to '' make it easier to take off'' . I could not disagree more as the previous chief instructor for the club. I prefer to fly the plane and not cause the plane to roll when I want or need it to yaw on take off or landing. He feels that it is a burden to teach a student to use the rudder to steer the plane and his justification is we have automatic transmission so we don't have to use a clutch anymore why even have a rudder control.
This sounds like the blind leading the blind, sounds like this instructor needs to go back and get some instruction on the great uses of rudder control...
Bob
Old 05-06-2013 | 04:30 PM
  #53
j.duncker's Avatar
ORIGINAL: sensei
ORIGINAL: Ron Stahl
Bob
Well I have taught some people to fly over the years and sometimes I would mix the rudder with ailerons if they were having trouble steering on take off. Usually they would learn to use the left thumb eventually but up till then it helped them get airborne safely.
I see nothing wrong in doing this.
Old 05-06-2013 | 05:27 PM
  #54
sensei's Avatar
Like I have always said, there are not bad students, only bad teachers. He stated the new instructor at their field teaches why use rudder, we don't use a clutch anymore because we drive cars with automatic transmissions... Eventually one would most likely learn to fly without the instructor, but why would he want to go that way?
Bob
Old 05-06-2013 | 06:50 PM
  #55
speedracerntrixie's Avatar
My Feedback: (29)
When I taught my kids to fly I would take a wingless trainer down to the schoolyard and have them drive it around. They learned how to start, tune the engine and rudder/throttle control before taking to the air. Once the flying started all three of them were flying around unassisted their first time out. I always teach rudder usage as early as I feel the student is capable.
Old 05-07-2013 | 04:13 PM
  #56
In this new day-and-age, many pilots are learning on the (in)famousHobbyZone SuperCub.
A 3-channel airplane with a steerable-tailwheel.
The dihedral will force rudder input to roll the aircraft, but the tailwheel remains on the right-stick?
I see no problems with teaching a student to program and use aileron-rudder mixing for coordinated turns.
So, long as the student knows that the mixing shouldn't be used as a crutch. It must be unlearned, eventually.
Same thing with automatic and manual-transmissions. Learn to drive both....</p>
Old 05-07-2013 | 05:03 PM
  #57
My Feedback: (29)
With very few exceptions coordinating turns with rudder is not necessary. It has the potential to create more issues then fix. learning to use your left hand early on is the best way to go.
Old 05-07-2013 | 05:46 PM
  #58
My Feedback: (15)
ORIGINAL: ssautter
...Same thing with automatic and manual-transmissions. Learn to drive both....</p>
Are you saying I have to teach my 19 yr. and 17 yr. old daughters to drive a stick? Never going to happen. I would rather fly Free Flight long before I do that!
Kurt
Old 05-08-2013 | 03:33 AM
  #59
sensei's Avatar
I agree with speed, learn to use both sticks from the beginning. NOTE: If your going call yourself a club instructor and instruct beginners to fly; then you have made this your own vast project and responsibility to instruct properly, so remember; don't start vast projects with half vast Ideas.... Can you imagine a full scale instructor placing rudder control on the yoke with the ailerons for his students.
Bob
Old 05-08-2013 | 03:34 AM
  #60
scale only 4 me's Avatar
My Feedback: (158)
Don't use Dual rates,, just learn to use the stick more precisely
Don't use Expo,, same as above
Don't use servo reversing, learn to set the plane up.
Don't use Sub-trim, same as above
etc.
etc.
All "crutches" right? I flew without those crutches for years too
Funny how you guy say "fly a Heli to hone rudder skills",, Apply this "don't use mixing" purest theory to helicopters,, and don't use a Gyro learn to use the rudder and you'd have a uncontrollable eggbeater crashing constantly,, "Cricket" anyone??
See these features on the radio make the flying experience more enjoyable and when used correctly make for a better flying more finely tuned machine, they don't replace flying or learning how,, they just make it better.
Disconnect the power steering and power brakes from your car and see how enjoyable that experience used to be,,
Old 05-08-2013 | 06:50 AM
  #61
Banned
"Same thing with automatic and manual-transmissions. Learn to drive both...."
If you first learn with a manual transmission, you can drive ANYTHING.
Les
Old 05-08-2013 | 07:48 AM
  #62
ORIGINAL: speedracerntrixie
I find this to be true on most of my warbirds. A few months ago I actually started to use the rudder to coordinate my turns using an Ares Gamma 370 Pro. The Gamma tended to drag the tail when banking so Istarted using rudder and the dragging tail stopped dragging! I then bought a Parkzone Albatross D.Va. I'm glad Istarted using rudder to coordinate turns because the Albatross almost requires that you use rudder to turn her. Iwould say that learning to use rudder for takeoffs and landings is a must. It is just an added benefit for coordinating turns. Use it. Idon't like to mix though. All my rudder use is manual.
Old 05-08-2013 | 04:59 PM
  #63
ORIGINAL: Bozarth
Kurt
I'll teach your 17 and 19 daughters to drive a stick!
Or ridethe stick .... whatever.
And, yes I fly free flight.
Old 05-08-2013 | 05:03 PM
  #64
Anyone else have a 17-19-year-old daughter?
</p>
Old 05-08-2013 | 08:05 PM
  #65
My Feedback: (15)
For all of the regular guys here at RCU, ssautter is a punk. Typical of what a dirtbag would type sitting safe in his momma's basement, but wouldn't dare say to my face. I am sad for you, ssautter. Your reputation will forever precede you. A real class act.
Kurt
Added: To the moderator: Please do not remove ssautter's little remarks. Give others the chance to see his character, or lack there of. I'm sure he will delete them very quickly. I purposely chose not to "quote" him.
Old 05-09-2013 | 03:47 AM
  #66
stevegauth30's Avatar
Yeah right? That crossed a line. who the @&$? Says that about another mans daughters? What a looser.
Old 05-09-2013 | 04:24 AM
  #67
frets24's Avatar
My Feedback: (15)
ORIGINAL: [email protected]
Wow! If I had ever found out one of my boys had a mouth on him like that, He'd have found himself cleaning himself up off the floor. Respect your fellow man, and especially the fairer sex.
Ssauter, your comments are vile on so many levels...but you seem to know that don't you. Seems you are a stirrer of the pot for attention.
Old 05-09-2013 | 06:41 AM
  #68
My Feedback: (15)
Where did ssauter's pathetic post go, along with my response? I had even asked the moderator to leave it up so the regulars here on RCU could see ssauter's wonderful comments. He is a true class act! We should all do our best to remember ssauter.
Kurt
Old 05-09-2013 | 06:47 AM
  #69
rye
My Feedback: (10)
OMG guys i just ask a question ,i didnt mean to start a war, i try it and didnt like it so i am going to have to learn the rudder ,so please let this one rest in peace ,thanks
Old 05-09-2013 | 08:48 AM
  #70
My Feedback: (158)
ORIGINAL: Bozarth
Kurt
It was way over the line, I agree, so I reported it,, RCKen deleted it along with other posts,, your post here is a personal attack,, also against the rules, Likely to be deleted also.
Why engage that behavior anyway,, you just give him the attention he seeks
Old 05-13-2013 | 10:58 AM
  #71
Well, if that is so... why don't you mix some elevator into the aileron channel? Why don't you mix some flaps in with the throttle? I agree with automation... use it to it's full extent. But, sometimes it does not make sense. Aileron and rudder mixing do NOT make sense. Yes learning to fly the tail on a heli will make you a better pilot because you are forced to use your left thumb in 2 axis. Nothing I hate worse than brushing back everyone on the flight line because some dolt can't or won't use some rudder on take-off.
ORIGINAL: scale only 4 me
etc.
etc.
All ''crutches'' right? I flew without those crutches for years too
Funny how you guy say ''fly a Heli to hone rudder skills'',, Apply this ''don't use mixing'' purest theory to helicopters,, and don't use a Gyro learn to use the rudder and you'd have a uncontrollable eggbeater crashing constantly,, ''Cricket'' anyone??
Old 05-13-2013 | 11:42 AM
  #72
Sport_Pilot's Avatar
ORIGINAL: Bozarth
ORIGINAL: ssautter
</p>
Kurt
Actually that would be more like "Free Fright" !
Old 05-13-2013 | 12:39 PM
  #73
My Feedback: (158)
ORIGINAL: on_your_six
etc.
etc.
One thing has nothing to do with another, mixing Rudder with AIL is a trim adjustment, just like that gyro/high speed servo on your heli. Neither replace the need to use the rudder during flight, I never said it did. Please try and not take my words out of context.
Why you guys focus on this line of argument is beyond me
Old 05-14-2013 | 07:03 AM
  #74
Banned
"Why you guys focus on this line of argument is beyond me '
There are some people who just like to argue.
Les
Old 05-14-2013 | 09:05 AM
  #75
Charlie P.'s Avatar
Do not!
