radio interferance
radio interferance
I am using a spectrum dx 8 transmitter and receiver and have started having problems with the plane noticeable glitch while flying .
I think I have solved the problem by removing the rcexl opto kill switch I am running a DLE-35 and have been flying it for more than 8 months without any problems until now I have changed the receiver switched transmitters with the same results after removing the kill switch the plane is back to normal
anyone else ever had this problem?
Bob
11-14-14
after flying the yak 54 several times the problem is back it was not the kill switch.I have now replaced the receiver switch and ignition module and need to test fly to see if its any better .
everything checks out on the ground just fine with the engine running. I use a 3 cell lipo batt. with a 10 amp bec for the radio and a 3 cell lipo and 10 amp bec for the engine I have checked all wiring and plugs
Thanks for every one that had an idea. anymore ?
Bob
11-14-14
IL
thanks, Bob
thanks, Bob
Thanks again
/cary
I would replace it with a different one and give it a try.
While a bad component isn't out of the realm of possibility, I have hundreds of flights with several of those switches installed.
Even if you are bent against the RCEXL, look at a Tech Aero or Smaart Fly because its a very good idea to run a transmitter activated kill switch with a gasser
Ditto on these switchs having no problems for me. I have 4 planes with them and no issues but I use Airtronics. Have you contacted Spectrum yet? Good to know a little more about your setup, single battery running everything etc.
My Feedback: (29)
I would be concerned about the use of 3 cell Lipo batteries. Depending on what the BEC input voltage is this could cause the BEC to heat up and put out inconsistent voltage/current. Verify BEC output voltage with a loaded meter after the system has been turned on for 5 to 10 min.
