WBPU vs Polycrylic
Can someone please explain the pros and cons of Water Based Polyurethane versus Polycrylic ? I see mention of both products in build threads and the terms seem to be used almost interchangeably.
I have not used either product, but am a long time user of nitrate & butyrate dope. My planned application for a water based product is to apply a light finish of silk to a foam model. The intent is to increase the rigidity of the foam and also provide a more durable surface. I've used lightweight fiberglas and resin in the past, but in this case the weight would be prohibitive.
Thanks in advance.
Dick
Thanks in advance.
Dick
