Futaba T7C
Futaba T7C
I have the above Futaba radio/transmitter. I purchased it used from a fella in the club I joined in FL a couple of years ago. It has a Futaba NiCd battery pack NT8S6008, 9.6 VDC 600mAh. The seller put a date of 9/15 on the side of it so I assume that's when he purchased it. To purchase a new one, it would cost around $45.00.
I found a battery pack on Amazon for $15.00. In the write up it does mention the Futaba number so I assume it's a replacement. It has physical dimensions listed so I'll compare it to the Futaba battery I have. This battery is a Ni-MH and is also 9.6 VDC but the capacity is 2000mAh. It is made by BAOBIAN.
I have two questions.
1) The battery I have now is dated 9/15 so that makes it 6 years old. Is it due to be changed or can it last longer. I have a electric Turbo Timber plane and I can get four 7 minutes flights out of this radio battery before I get the low battery warning.
2) What is the difference between a NiCd battery and a Ni-MH battery? Will this new battery work for me and will it last as long as the Futaba battery.
Thanks to all who respond. I'm a Newbie so please bare with me.
I’d change it
Sounds like there’s not much left to that battery.
you should get more flight time than that.
like said above if it fits it’s good.
you will need a charger though.
