Fuel Proofing...How
Banned
Porous... like a sponge = full of holes. The epoxy lets the fuel seep through it. If the alcohol can evaporate out of the epoxy... then its full of holes and can let the fuel in.
Its kind of like trying to hold water in a piece of window screen... it just doesn't do a good job.
Moderator
My Feedback: (58)
You can eliminate any "porosity" in alcohol-epoxy mixture by not using too much alcohol and leaving it to cure in a cooler place in the house to avoid rapid outgassing that may lead to the "porosity".
Even if there's any "porosity" it's normally "closed porosity" and not "open porosity". Fuel should not seep through that layer as per Minnflyer. Did I cause enough confusion ?
Yes, works real good....so does thin CA-even though I'll catch a lot of flack for that one (did before) Rustoleum, epoxy ect. the choice is yours. Your dope would be color matched though.
Jetts
Jetts
Banned
The only problem with CA for fuelproofing... Nitro can dissolve CA. The CA is fine for protection from the exhaust oil... but fresh fuel can remove it.
It takes a while... or CA hinges would be serious problem
Told you so! Told you so!!!! I knew I'd hear it!
Yes FH, it will soften it after awhile, a loooong while, but I've used this method on quite a few planes, and they always ended up uh...."retired" before the fuel proofing went away.
Jetts
Jetts
NY
So I can just squirt thin ca all over the engine area or I can use epoxy thinned with alcohol. If i use the epoxy how do i know how much alcohol to use? What Rustoleum and where can i get it?
Also can someone PM me, for some reason im not recieving any PM's...
Moderator
My Feedback: (58)
Nmtr, don't use ca in such a large amount. You might develop ca allergy and respiratory problems. Even when used in small amounts, do it in well ventilated areas.
Here's a thread on alcohol/epoxy ratio :
http://www.rcuniverse.com/forum/m_14...tm.htm#1408587
With finishing epoxy, you don't have to add anything
Did you manage to resolve your hinge gap problem ?
NY
Yes its much better now, before i did it i got scared because i thought i would have to take off the vert. stab. to get the elevator off but i didnt have to.
Yes, rubbing alcohol will work, just add a bit after you've mixed the epoxy 'til it's the consistancy you want (like paint).
Thin CA you can use drop by drop, but as posted above, don't get carried away, don't breath the fumes, and yes it will be marginaly more expensive.
Rustoleum is available at K/Wal-Mart, Lowe's, Home Depot, ect.
Clear (or pigmented) dope is real cheap, already the right consistancy, and fuel proof right out of the container.
Jetts
Jetts
Banned
watch out with denatured alcohol... that porosity thing I mentioned above... gets worse as the water content increases. Not all rubbing alcohol is equal.
Also... rubbing alcohol can turn the epoxy rubbery. If that happens... you CERTAINLY have no strength from the epoxy (not as big a deal for fuelproofing as other places...) and... the epoxy can just peel free of the wood with no warning. (Then it definitely isn't helping fuelproof anything.)
Messing with the chemistry of epoxy just isn't worth the headaches it can cause... Yes some people get great results. I have TRIED the alcohol... and followed the directions given by the experts on doing that EXACTLY... and ended up with a goo that never set up.
