Prop Reaming?
Old 03-23-2004 | 09:44 AM
My Feedback: (23)
Default Prop Reaming?
Can someone tell me how to "ream" a prop from 1/4" to 10mm for a G-45? I have a MA-20x6 prop and I don't see any reams that go up to 10mm?
Tony Allen[]
Old 03-23-2004 | 09:52 AM
Primodus's Avatar
My Feedback: (56)
Default RE: Prop Reaming?
Use a drill bit, the main thing is to keep the shaft hole centered.
Old 03-23-2004 | 09:58 AM
MinnFlyer's Avatar
Yes, a drill bit will work fine. The drill will usually center itself by following the existing hole.
Old 03-23-2004 | 11:30 AM
You can buy a step reamer for larger props from many places such as B&B Specialties if your local hobby shop dosn't carry them... their web site is: http://www.bennettbuilt.com/. They will have the correct size you need for a reasonable price... it will result in a perfectly centered hole every time. Good luck.
Dan
...And clamp the prop down so it doesn't bind on the bit and start spinning.
Old 03-23-2004 | 02:49 PM
MinnFlyer's Avatar
Actually, you don't want to CLAMP the prop down.
You DO want to restrict it's movement, but you also want it to be able to wobble just a bit so that the drill can find it's way to center.
Old 03-23-2004 | 04:09 PM
Patriot's Avatar
Actually, Tower Hobbies has a prop reamer that is 10-12mm manual reamer made by Fox. I have the 7-8-9mm Fox reamer and it works great.
Patriot
Old 03-23-2004 | 04:14 PM
I bought a tapered machinist's reamer years ago at a tool store; it goes from 1/8" to 1/2" and cost me less than ten bucks.
Old 03-23-2004 | 04:24 PM
Deadeye's Avatar
ORIGINAL: MinnFlyer
That's how I do it, my prop reamer lasted about 4 props.
Old 03-23-2004 | 06:31 PM
My Feedback: (16)
I use a drill bit and press to drill my holes.
Works great for me.
Old 03-24-2004 | 02:38 PM
My Feedback: (23)
Thanks everyone! I'll try the drill method and see how it turns out.
