WING LOAD
Old 07-02-2004 | 09:38 AM
Default WING LOAD
Hi all! I'm trying to figure wing load for a Byron Beechcraft Baron 58. Does anyone know the formula for this?
Old 07-02-2004 | 09:43 AM
MinnFlyer's Avatar
Default RE: WING LOAD
Divide the total weight by the wing area.
So if your plane weighed 10# (160oz) and your wing was a total of 780 Sq In:
160/780= .205 oz per sq in
Old 07-02-2004 | 09:44 AM
Thanks Mike !
Old 07-02-2004 | 05:39 PM
Just as an added note, wing loading is usually stated per square foot so you would need to take the .205 from the above example and multiply it by 144.
Old 08-08-2004 | 10:29 AM
zoro4's Avatar
Stick Jammer, what is optimal wing loading? I herd it is 16lbs per square foot, is that correct?
Old 08-08-2004 | 11:15 AM
There is no universal optimum wing loading. Having too little wing loading is not good, nor obviously, is too much -- sooo optimal wing loading is specific to each aircraft type & use. 16 lbs/sq ft would be very light for a warbird & perhaps too heavy for a park flier.
Old 08-08-2004 | 11:25 AM
16#/sq. ft. would be extremely heavy for any model. 16 oz/sq. ft would be light for a .40 size trainer. In .40 size trainer or sport, I try for less than 20 oz/sq. ft. A glider or slow flyer would be much less while a warbird would be more.
Old 08-08-2004 | 12:27 PM
Ed_Moorman's Avatar
Unless you are flying a light weight fun fly plane you will have a hard time getting much under 20 oz/sq-ft. The NexStar trainer from the Tower flier is listed at 722 sq in and 6.5 #. This is 20.75 oz/sq-ft. Most all sport planes will have a higher wing loading than this.
Generally, wing loading is size dependent. Smaller planes need a lighter wing loading to fly well than do larger planes. Sport planes in the .40-.61 size will be in the 20's. Over 30 and they are going to start feeling heavy. .91-1.20 size planes will go into the 30's. The bigger planes will tolerate higher values. Large warbirds can be in the 40's and fly OK. In a .46 sized plane, this would be a crash waiting to happen.
A math short cut is to divide pounds weight by wing area in square inches, then multiply this result by 2304.
Old 08-08-2004 | 01:43 PM
My Thunder Tiger Stick, stock, with a Thunder Tiger Pro46, and Futaba radio was under 5 1/2 pounds for a wing loading of 17 oz/sq ft. The trainer was slightly less than that. My Balsa USA Stick 40+ with a Thunder Tiger GP42 has a wing loading of just under 20 oz/sq ft because of the smaller wing area. The Sig Citabria has a wing loading of 20.4 oz/sq ft. These are what my statement is based on. From my experience, most .40 size trainers should come out between 5 1/2 and 6 pounds dry.
Old 08-09-2004 | 11:48 AM
zoro4's Avatar
I'm new to wing loading calculation, I've listened to many opinions, seems I got it wrong. I think I've got it now; Divide the wing area by 144 to convert square inches to square feet, then divide the weight ( ounces ) by the wing area ( in square feet )= ounces per square feet.
Old 08-09-2004 | 03:12 PM
Did I really say lbs? Sorry folks it's the little ones (oz).
Old 08-09-2004 | 03:18 PM
TLH101's Avatar
My Feedback: (90)
zoro,
You are correct.
Old 08-10-2004 | 05:08 PM
Jemo's Avatar
http://www.gsal.org/tools/Wing_Laoding.htm
