Setting up pull pull
NY,
My Great Planes Ryan comes with a pull pull system. I've never used this system before and there are no instructions on how to make the cables. There are 4 metal clevises with a threaded rod for each. The rods have 2 pairs of holes for the cables but I don't know how to attach the cables to the threaded rods.
Can someone explain how I should do this
Jeff
Jeff
You make the cables up as if you were making wire traces for fishing. There should be some crimps somewhere (small metal tubes) which you pass the cable through, then through the hole in the threaded rod and back through the crimp, then with a pair of pliers (or crimping tool[recomended]) you squeze the crimp.
Cheers,
Cheers,
