 Applying Decals >
Applying Decals
Applying Decals
Old 08-04-2004 | 01:12 PM
Default Applying Decals
I've finally finished (more or less) my GP .60 Cub. Maiden was this weekend, but I haven't put the decals on yet. Are there any tricks to a successful application? I believe they are the press on adhesive type. I am applying on Monokote.
I have heard vague reference to spraying the surface with Windex so you can float them into position. Is there anything more to it? Also, should I install the large number decal on the wing in one piece, or cut each individual number out? Is there anything I can do to make sure they don't come off after use? Will they actually stay on?
Scott
Old 08-04-2004 | 01:41 PM
Connery's Avatar
Default RE: Applying Decals
With adhesive backed decals I've used both of these methods with sucess. The first is the windex method you mentioned. Some people spray the windex on the surface but I spray mine on the decal itself. Then place it into position and then when it's in place, use a credit card or small squeegy to get all the airbubbles and excess windex out. Then just let it dry overnite. The other method is basically the same proceedure except instead of using windex, I used warm water in a bowl with a couple of drops of liquid detergent.
Old 08-04-2004 | 01:43 PM
Thanks, Connery. Do they stay in place pretty well once they're on?
Old 08-04-2004 | 01:47 PM
Campy's Avatar
ORIGINAL: jagnweiner
Scott
Use the Windex or the dish soap/water method to float them in position. After they have dried, take some MonoKote solvent (trim solvent ? - in any case it comes in about a 3 oz bottle ) and using a q-tip go over all the edges of the decal. This will seal the decal edges down.
Old 08-04-2004 | 04:08 PM
rcmiket's Avatar
The windex thing works great just make sure to get all of it out from under the decal, the credit card thing works really good.-Mike
Old 08-05-2004 | 09:31 AM
hookedonrc's Avatar
I also wrap a paper towel across the edge of the card so that the liquid is soaked up as it exits from under the decal. It keeps things neat and also softens the edge of the squeegie tool.
