Covering cowling?
MO
Covering cowling?
I plan on covering my ultra sport in flourescent covering ,but I can't find paint to match.Is it possible to use the covering on the cowling,would it shrink enough?Has anyone done it?How did it look?
My Feedback: (15)
CA
RE: Covering cowling?
I covered my cowl (fiberglass) with monokote, cause I couldn't even get a paint match from a paint store. Go slow, and be carefull with the heat. Plastic may not work under heat... Here's a pic of my cowl....
MO
Thanks all, for those that used mono/ultra cote.Did you apply then apply heat to remove wrinkles or use heat to stretch the covering over the compound curves?
