Wing retention
Wing retention
How do you retain plug in wings?
I am putting together a third scale cap231, it is composite and has wing tube and incidence dowels. It has been flown by its previous owner with a metal hoop on each wing half which goes into the fus and gets cable tied together. I think this is adequate but I want to move the tank back to the c of g and it would get in the way.
Any ideas would be great. Thanks in advance
FL
RE: Wing retention
Typically nylon screws are used between the dowels and the tube. Others have used the setup you describe but rather use a couple of rubber bands to hold the wing halves together, which might allow you to pull the rubber bands over the tank and still do the job (versus the cable).
Whatever you do, DO NOT drill a hole in the wing tube and put screws in.
RE: Wing retention
ORIGINAL: aviefly
Then, I bought a package of toilet seat bolts, which come with plastic wing nuts. Removed the head from the bolt, epoxied the bolt into the foam, and let it cure. The bolt slides right into the fuselage, and I snug the wing nut down on it when assembling at the field.
You could do something similar, even if your wing has no core.
Best wishes,
Dave Olson
RE: Wing retention
Toilet seat bolt thats the answer for it.
Great idea it's perfect the wings and the big flat bottom area to spread the load.
I fitted a toilet seat at home the other week and it never clicked.
GA
RE: Wing retention
Scar,
That's a great idea. I like the idea of a wing nut applied to a stud versus a bolt into the wing. Anything to make assembly at the field easier is the way to go! [8D]
Nice Post
Nice Post
