Is Testor's spray enamel fuel proof?
I've got a complicated covering project going on with a 3-D American Flag on my CAP-21. I need to paint the fiberglass cowl to match the blue starfield. As a result of it being 3 dimensional, I need the blue to be translucent or transparent (shading under the blue, etc.). I took a sample to the automotive paint guys and they say they have a good match, but I haven't seen it yet. I picked up a 3 oz can of Testor's Candy Blue enamel at my LHS. With several coats, I can get the blue hue down almost perfectly. My questions are these, now that I have what looks like two options. Is the Testor's spray enamel fuel proof? The cowl is big, and I wonder if the spray can pattern is going to look like hell. The automotive paint uses a catalyst, and they assure me it will be fuel proof with no clear coat. I can shoot it with a paint gun, probably giving me more universal coverage. Only drawback this way, is I have to use the paint in a day or two, and its going to cost $40 for a pint!! Thanks for your time.
My Feedback: (60)
RE: Is Testor's spray enamel fuel proof?
I always suggest catalyzed paint over non, but have to ask you if the paint they auto guys are suggesting is a base coat/ clear coat paint or a "single stage" all in one, mix paint with catalyst.
Your description suggests that they are suggesting a "single stage" which is by the way, fuel proof, but thought to ask to make sure.
I know it's costly, but the end result is SO worth it!!
I can't comment on testors, as I always clear coat over the testors when I've used it. The clear coat is fuel proof.
It's a single stage. Is the clear coat that you use over Testors Testors clear coat? And it is fuel proof?
My Feedback: (24)
I would use either LustreKote or UltraCote clear over fully dried Testors enamel. Both LustreKote and UltraCote clear can handle up to 15% nitro. If you are using more than 15% nitro, then you must use Nelsons clear or automotive clear, although I'm not sure if Nelsons clear is compatible with enamel paint.
